Re: 69 B Body carb. spring ?
[Re: 5carguy]
#2448349
02/08/18 04:39 AM
02/08/18 04:39 AM
Posts: 5,439 So Cal
Sinitro
So Cal
EZ to check.. Disconnect throttle cable, and now check throttle action.. Does the idle return back down? Just my $0.02..
[Re: 5carguy]
#2449147
02/09/18 04:40 PM
02/09/18 04:40 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
Though the spring is in the wrong position I think the problem is the spring itself , a little too long or not the right specs to pull the throttle fully closed?
ASSuMEing the butterflies are not hitting anything ?
