Rekey New Ignition Tumbler to Match Old? #2447816
02/07/18 01:31 AM
02/07/18 01:31 AM
Oklahoma
Mopar72Man Offline OP
Oklahoma
The chrome thumb rest part of my 70s Dodge pickup just spins and it causes issues with getting the key inserted, unless it's aligned just right.
I have ordered a new ignition tumbler but would like to keep the key I have now since it matches the door. Is it reasonable for me to be able to DIY that? Any other recommendations?
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: Rekey New Ignition Tumbler to Match Old? [Re: Mopar72Man] #2447820
02/07/18 01:38 AM
02/07/18 01:38 AM
Kirkland, Washington
Pacnorthcuda Offline
If the new tumbler is a true replacement, the segments--little brass cylinders of different lengths---can be swapped from your old lock to the new. It's the configuration of these that determine the shape of the key that will cause them to line up and allow the lock to rotate.
It's kinda tedious, but fun nonetheless. These segments look like pieces of cigarette lighter flint. Don't get them mixed up.
You'll figure it out. It's like solving a puzzle.
Re: Rekey New Ignition Tumbler to Match Old? [Re: Pacnorthcuda] #2447832
02/07/18 01:52 AM
02/07/18 01:52 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Or the pins can be arranged properly by a locksmith.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Rekey New Ignition Tumbler to Match Old? [Re: Mopar72Man] #2447866
02/07/18 03:05 AM
02/07/18 03:05 AM
I'm assuming the old/new cyls are the same type with the chrome rectangular cover. Yes just swap the tapered pin tumblers/spacer pins/springs from each of the 5 holes into the same 5 holes in the new cyl & you're set (springs are the same tho). each holes' combo of pin/spacer height matches the depth of the corresponding notches in the key. Actually if you are ever missing some pieces on a swap like this you can easily get by with 2 or 3 or the holes empty as no one picks locks anymore (exc in the movies). wouldn't hurt to clean everything & lube it with some powered graphite (parts house or lock shop) but not critical & cleaning those small parts is a royal pain. EDIT the "tabs" on the chrome cover are stiff/easily broken, move them just enough to get the cover off.
Re: Rekey New Ignition Tumbler to Match Old? [Re: Mopar72Man] #2447872
02/07/18 03:21 AM
02/07/18 03:21 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You could always just dump the pins out of the new one and use your old key. Or any key or no key at all.
I want my fair share
Re: Rekey New Ignition Tumbler to Match Old? [Re: Mopar72Man] #2447959
02/07/18 12:31 PM
02/07/18 12:31 PM
ohio
bbtrux Offline
bbtrux  Offline
ohio
For the money, just take your key and cylinder to a locksmith and have him sell you a new one keyed right. Every time ive done that, hes within 20 bucks of my cost for a part store cylinder thats not keyed right.
Re: Rekey New Ignition Tumbler to Match Old? [Re: Mopar72Man] #2447961
02/07/18 12:36 PM
02/07/18 12:36 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I just went through this. I took my old key and new tumbler to a locksmith. Cost me 24.00
Re: Rekey New Ignition Tumbler to Match Old? [Re: Mopar72Man] #2448025
02/07/18 03:01 PM
02/07/18 03:01 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's easy to re-key the locks with the pins from your old cylinder. Not worth paying somebody $24 to do, in my opinion.
Re: Rekey New Ignition Tumbler to Match Old? [Re: bbtrux] #2448054
02/07/18 03:51 PM
02/07/18 03:51 PM
RSNOMO Online rolleyes
Moparts Torchbearer
RSNOMO  Online Rolleyes
Moparts Torchbearer
Uh-huh...
Ain't worth the potential problem of a worn key and/or 'lock'...
Re: Rekey New Ignition Tumbler to Match Old? [Re: RSNOMO] #2448055
02/07/18 04:04 PM
02/07/18 04:04 PM
Uh-huh...
OP asked if there is a DIY solution, to which he received info about exactly that. God forbid he learns something that will serve him now and in the future. What we described is exactly what a locksmith does.
Re: Rekey New Ignition Tumbler to Match Old? [Re: Pacnorthcuda] #2448469
02/08/18 01:18 PM
02/08/18 01:18 PM
Minn
SportF Offline
SportF  Offline
Minn
Uh-huh...
Remember gang, this is the internet, and proper internet troubleshooting protocol dictates one do the most time consuming, difficult, and expensive things first, then work backward from there.
Re: Rekey New Ignition Tumbler to Match Old? [Re: Pacnorthcuda] #2448506
02/08/18 02:22 PM
02/08/18 02:22 PM
Moparts Torchbearer
Moparts Torchbearer
Overheard somewhere on the left coast:
"Gosh darnit...
If Tom Brady can re-work a lock cylinder, so can I"...
