Correct Stock Steel Wheel For 67 GTX? #2447855
02/07/18 02:42 AM
02/07/18 02:42 AM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
What is the stock steel wheel for a 1967 GTX? 14x5.5"? Hollanders does not specify GTX in the listings. Also, any difference in the stock wheel on a 440 car vs. a Hemi?
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2447859
02/07/18 02:53 AM
02/07/18 02:53 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
1967 14 x 5.5 Steel wheel and are not easy to identify. They are often confused with later 14 x 5.5 Mopar rims. There is normally (but not always) a "5" stamped on either side of the valve stem hole, sometimes the 5 on one side is followed by an "L". Wheels made after the end of March 1967 have date stampings, earlier wheels do not.
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2447871
02/07/18 03:17 AM
02/07/18 03:17 AM
Highland, MI.
Highland, MI.
Excellent - thank you!
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2447877
02/07/18 03:44 AM
02/07/18 03:44 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's a 5.5 with the "L"
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2447878
02/07/18 03:46 AM
02/07/18 03:46 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Two more examples. Sometimes the stampings were very shallow. notice the "Eyebrow" stamped on the right in the first one? That is an imprint from the stamping die that surrounded the 5. The 5 failed to leave a good impression on this example (barely visible). Second pic shows the same witness mark AND the 5 which is easier to see.
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2447887
02/07/18 05:05 AM
02/07/18 05:05 AM
A727Tflite Offline
A727Tflite  Offline
Where they body color in 67?
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2447930
02/07/18 11:28 AM
02/07/18 11:28 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, if equipped with standard nut covers they were body color in 67. Full wheel cover cars were always black.
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2447950
02/07/18 12:17 PM
02/07/18 12:17 PM
A727Tflite Offline
A727Tflite  Offline
Makes sense!
Next question - what is the correct poverty cap for 67 Plymouth - were satellites ever available with poverty caps or just wheel covers? I see all kinds of stuff on the web, haven't found a sales brochure yet so don't know what is fact.
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2448006
02/07/18 02:16 PM
02/07/18 02:16 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Satellites had standard items, like full wheel covers and AM radio. I have never seen a 67 Satellite without the fender mounted turn signals indicators.
The 68 wheels have a different wheel center stamping around the lug nut area, and they take a smaller diameter poverty cap. 68's also have a different shape to the rim behind the wheel center.
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2448039
02/07/18 03:27 PM
02/07/18 03:27 PM
Highland, MI.
Highland, MI.
Scott, as far as the wheel stampings I have seen them all - very light & impossible to read, to nice, sharp stampings. I've sold many big H wheels where the "H" was barely visible & many that had a nice, bold H. Same thing with all the other stampings - sometimes they are very light. Ford wheels with the Ford oval range from one extreme to the other. I had a supply of 15x6" Ford wheels NOS from K-H in Venezuela that were genuine wheels, but none of them had the Ford oval stamp in them.
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2448062
02/07/18 04:15 PM
02/07/18 04:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The only correct 67 poverty caps, standard.
Satellite was standard full wheel cover, upgrade options were simulated mag full wheel cover and chrome road wheels.
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2448070
02/07/18 04:37 PM
02/07/18 04:37 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Optional full wheel cover on Belvedere/GTX, standard on Satellite (wheel is incorrectly painted body color on this example)
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2448379
02/08/18 09:52 AM
02/08/18 09:52 AM
Haryana, India
joebrowntech Offline
Haryana, India
For a GTX 1967, you could get information about the stock wheel in the manual of the vehicle.
However, if you do not contain the user manual, you could get one free of cost online on Manuals.co , when you register a few details about your vehicle.
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2448412
02/08/18 11:32 AM
02/08/18 11:32 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
rolleyes
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2451663
02/14/18 02:25 PM
02/14/18 02:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here are some more pics. These were off of an early built 67 R/T Coronet. They show the style typical of a 1966 14x5.5 with the added axle pin holes between each lug hole. After early 67 they started receiving wheels that were the same but only had one axle pin hole between two lug holes.
Re: Correct Stock Steel Wheel For 67 GTX? [Re: Sunroofcuda] #2451664
02/14/18 02:26 PM
02/14/18 02:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Inside, same wheel
