D sereis BB 440 oilpan measurements needed, please help
#2447837
02/07/18 02:00 AM
02/07/18 02:00 AM
Posts: 43,119 Bend,OR USA
Cab_Burge
I have a 440 motor that was brought to me to assemble with a OEM rear sump oil pan that the customer doesn't know what year or which type Mopar chassis that it came off of I assumed that it was off a Class A motorhome motor but it may not be, it might be off of a 413 truck motor he had Do any of you know the stock depth and width of the stock 440 or 400 D series pickup oil pans Thanks in advance, this will help me decide if it needs 6 quarts or eight quarts of oil in this pan
Re: D sereis BB 440 oilpan measurements needed, please help
[Re: Cab_Burge]
#2447916
02/07/18 10:46 AM
02/07/18 10:46 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Front sump pans were class A motor home and 71-older pickups trucks. 72-up pickup trucks are rear sumps and are 6 qts.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2448019
02/07/18 02:34 PM
02/07/18 02:34 PM
Posts: 760 Canada
CTD5.9
Canada
Front sump pans were class A motor home and 71-older pickups trucks. 72-up pickup trucks are rear sumps and are 6 qts. 361's and 413's are rear sump 8 quart pans in medium duty D500-D800's if Cab has one of those it will be 8.
[Re: CTD5.9]
#2448022
02/07/18 02:45 PM
02/07/18 02:45 PM
moparmarks
Front sump pans were class A motor home and 71-older pickups trucks. 72-up pickup trucks are rear sumps and are 6 qts. 361's and 413's are rear sump 8 quart pans in medium duty D500-D800's if Cab has one of those it will be 8. Good to know. Thanks
[Re: CTD5.9]
#2448058
02/07/18 04:12 PM
02/07/18 04:12 PM
Cab_Burge
Thanks to all of you for the help I ran this motor on a engine run stand last week with 8 quarts in it to break in the cam and lifters, I didn't see any bubbles or frothing on the dipstick that screws into the oil pan fitting so I thought I should ask for help on here to see if I can figure out if this pan is the pickup or the larger truck pan Thanks again for all the help Cab
