Re: Rekey New Ignition Tumbler to Match Old?
[Re: Pacnorthcuda]
#2447832
02/07/18 01:52 AM
02/07/18 01:52 AM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Or the pins can be arranged properly by a locksmith.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Mopar72Man]
#2447866
02/07/18 03:05 AM
02/07/18 03:05 AM
RapidRobert
I'm assuming the old/new cyls are the same type with the chrome rectangular cover. Yes just swap the tapered pin tumblers/spacer pins/springs from each of the 5 holes into the same 5 holes in the new cyl & you're set (springs are the same tho). each holes' combo of pin/spacer height matches the depth of the corresponding notches in the key. Actually if you are ever missing some pieces on a swap like this you can easily get by with 2 or 3 or the holes empty as no one picks locks anymore (exc in the movies). wouldn't hurt to clean everything & lube it with some powered graphite (parts house or lock shop) but not critical & cleaning those small parts is a royal pain. EDIT the "tabs" on the chrome cover are stiff/easily broken, move them just enough to get the cover off.
[Re: Mopar72Man]
#2447872
02/07/18 03:21 AM
02/07/18 03:21 AM
Posts: 10,198 Someplace you aren't
SomeCarGuy
You could always just dump the pins out of the new one and use your old key. Or any key or no key at all.
I want my fair share
[Re: Mopar72Man]
#2447961
02/07/18 12:36 PM
02/07/18 12:36 PM
Posts: 4,319 St. Louis, Mo
318 Stroker
St. Louis, Mo
The chrome thumb rest part of my 70s Dodge pickup just spins and it causes issues with getting the key inserted, unless it's aligned just right.
I have ordered a new ignition tumbler but would like to keep the key I have now since it matches the door. Is it reasonable for me to be able to DIY that? Any other recommendations? I just went through this. I took my old key and new tumbler to a locksmith. Cost me 24.00
[Re: bbtrux]
#2448054
02/07/18 03:51 PM
02/07/18 03:51 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
have him sell you a new one keyed right. Uh-huh... Ain't worth the potential problem of a worn key and/or 'lock'...
[Re: RSNOMO]
#2448055
02/07/18 04:04 PM
02/07/18 04:04 PM
Posts: 21,814 Kirkland, Washington
Pacnorthcuda
have him sell you a new one keyed right. Uh-huh... Ain't worth the potential problem of a worn key and/or 'lock'... OP asked if there is a DIY solution, to which he received info about exactly that. God forbid he learns something that will serve him now and in the future. What we described is exactly what a locksmith does.
[Re: Pacnorthcuda]
#2448469
02/08/18 01:18 PM
02/08/18 01:18 PM
Posts: 1,210 Minn
SportF
Minn
have him sell you a new one keyed right. Uh-huh... Ain't worth the potential problem of a worn key and/or 'lock'... OP asked if there is a DIY solution, to which he received info about exactly that. God forbid he learns something that will serve him now and in the future. What we described is exactly what a locksmith does. Remember gang, this is the internet, and proper internet troubleshooting protocol dictates one do the most time consuming, difficult, and expensive things first, then work backward from there.
[Re: Pacnorthcuda]
#2448506
02/08/18 02:22 PM
02/08/18 02:22 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
OP asked if there is a DIY solution, to which he received info about exactly that. God forbid he learns something that will serve him now and in the future. What we described is exactly what a locksmith does. Overheard somewhere on the left coast: "Gosh darnit... If Tom Brady can re-work a lock cylinder, so can I"...
