#2447345 - 02/06/18 10:02 AM Air Gap intake and factory AC
WadeMetzinger Offline
Loc: Tulsa, Ok
Can you run the Edelbrock Air Gap intake on a SB and still run the factory A/C?
I’m not sure if there were issues with clearance or mounting bracket so I figured I’d ask you guys.
This will be in a 1968 Barracuda.
Thanks for the help in advance!
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
#2447561 - 02/06/18 04:22 PM Re: Air Gap intake and factory AC [Re: WadeMetzinger]
MarkM Offline
Worthy
Loc: USA, MI
The RPM Air-Gap and Performer RPM both have the water neck in a different location than stock. I know for sure that it interferes with A/C on later model cars that use the Sanderson compressor. It can be overcome with custom brackets - I've seen it done. Can't speak to the older stuff though.
Edited by MarkM (02/06/18 04:23 PM)
'87 Fifth Avenue: 512 / 518 / D60
#2447719 - 02/06/18 07:58 PM Re: Air Gap intake and factory AC [Re: WadeMetzinger]
dfsmopars Online   content
Loc: Kentucky
I put an Air Gap on a 5.9 in my ‘72 Charger. Top radiator hose is on the left side. Installed a Sanden A/C compressor from ACC with their supplied brackets. Had to be a little clever with the heater hose fitting it all worked out well.
Probably have pictures stored on a flash drive if they would help.
Edited by dfsmopars (02/06/18 08:00 PM)
25,741 Registered Members
192,958 Topics
I think I might have a problem
by DUFFMAN
02/20/19 10:32 AM
trunk mat
by otter440
02/20/19 09:18 AM
Fender Installation Tips From AMD & Classic Muscle Metal
by Rustymuscle
02/20/19 07:42 AM
Congrats moparts member Goody's cuda in Mopar action
by rdrnr6970
02/20/19 05:41 AM
