Page 3 of 3 1 2 3
Re: 6 pack metering block question [Re: BSB67] #2452103
02/15/18 01:26 PM
02/15/18 01:26 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted By BSB67
Originally Posted By mickm
I have it farther down, in the 14+ range, just turns the screws farther out.
I'm just going to live with it. There are other things that need attention, this is just more of a nuisance than anything else.
I didn't expect it to take this much time and energy, but since it is what it is and doesn't harm anything, it's good enough.
If you have a large overlap cam you should be focusing on idle quality, not what an O2 meter is reading. It simply does not read right. If the O2 meter is reading 15:1 the the combustion charge AF ratio could still be far too rich. Some have reported as high as 18:1 meter reading at best idle quality w a big cam
iagree
Make it idle happy. The AFR will land where it lands.
Every time it misfires, all the O2 that didn't get used for combustion goes out the exhaust and a big overlap cam misfires A LOT at idle. That's why an engine idling pig rich can indicate 18:1 dead lean.
Kevin
Re: 6 pack metering block question [Re: Twostick] #2452116
02/15/18 01:59 PM
02/15/18 01:59 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My FAST portable wideband wouldn't even read my air-fuel ratio at idle. It's beyond it's range, because its too rich. I changed my cam and compression, and am a day or two away from seeing if it will read it with this one.
Re: 6 pack metering block question [Re: mickm] #2452125
02/15/18 02:19 PM
02/15/18 02:19 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Is everyone setting idle mix by adjusting to highest idle speed or vacuum reading?
after I threaded the IFR's in my metering blocks and dropped the IFR size down, I figured I would be close to the typical 1.5 turns out from seated so I set them up initially at 1.25 turns out.
It started and idled OK, kinda bumpy, kinda stinky.
after it warmed up all the way I started leaning them out, idle goes up, smooths out. keep going around the carb, a tad leaner every time. Ended up at just a touch more than a half turn out.
I was thinking wth, after all this work these should be further out, then I figured well, I dropped the IFR down but the I didn't touch the idle bleeds and they are roughly .067", pretty small.
The idle smoothed out, smells much cleaner (still smells like it has some overlap), I had close the blades to drop the idle back down...it starts up with just a touch of the key when it's warmed up...I'm just gonna worry about other things now and leave the idle screws where the motor likes them.
Re: 6 pack metering block question [Re: Twostick] #2452233
02/15/18 05:35 PM
02/15/18 05:35 PM
California
mickm Offline OP
mickm  Offline OP
California
iagree
Kevin
Yeah, got it. I usually do it with a vacuum gauge. Will start again there and see where it ends up.
Re: 6 pack metering block question [Re: mickm] #2452425
02/16/18 02:33 AM
02/16/18 02:33 AM
California
mickm Offline OP
mickm  Offline OP
California
Cam is 248/255, .604/.582 LSA 112 on a 110 centerline.
That doesn't seem big enough to be the cause of my idle stink!
Page 3 of 3 1 2 3
