Starter cable gage needed #2447524
02/06/18 06:41 PM
02/06/18 06:41 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Im using CSR starter on my 511. Had trouble with it disengaging and engaging while rolling engine over. I want to replace the starter cable which runs from cut off switch to starter. Currently have 6 gage cable, want something larger. CSR says i need 00 gage. Do i really need that huge cable? Gonna change out the battery as well.
Re: Starter cable gage needed [Re: mopar dave] #2447553
02/06/18 07:12 PM
02/06/18 07:12 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Yes, need at least 0 if not 00. Wait till the motor's good and hot and you'll find out real quick need all the amps the battery can deliver. 0 or 00 will be peace of mind that it will crank when ever.
Re: Starter cable gage needed [Re: mopar dave] #2447562
02/06/18 07:23 PM
02/06/18 07:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I use 2ga on everything for the main cable. Master switch to a junction in the firewall area. Distributed from there to starter relay, switch panel, etc. Good 2ga, fine strand welding cable. Big motors, high compression, whatever. Lighter, easier to work with. Never a problem. Never an issue st the track. All the chassis guys - Bickel, RJ - sell the same thing for their stuff. Don't use a junk starter.
Re: Starter cable gage needed [Re: mopar dave] #2447629
02/06/18 09:17 PM
02/06/18 09:17 PM
CA
crackedback Online content
crackedback  Online Content
CA
Dave,
6ga? Stock cables are 4ga IIRC
Simple deal, larger wire is more efficient. Most vendors sell wire that is undersized for the applications. If you street drive the car, larger wire is better especially in hot start situations.
I sell 1/0 battery cable and they are stout and do the job with minimal voltage drop.
Weight is not an issue. A 1/0 wire of 15ish feet weighs about 3 pounds more than a 2 gauge wire of same length.
A 15' 2 ga wire weighs 4.2 pounds
Same in 1/0 is 6.9 pounds
You could do 2/0, not really a big step up from 1/0
Re: Starter cable gage needed [Re: CMcAllister] #2447650
02/06/18 09:40 PM
02/06/18 09:40 PM
Mt Morris Michigan
Mt Morris Michigan
Are you saying the csr starters are no good? I used same starter on my small and never an issue. It only disengages while starting hot, never cold.
Re: Starter cable gage needed [Re: mopar dave] #2447658
02/06/18 09:44 PM
02/06/18 09:44 PM
Washington
madscientist Offline
Washington
Your cable is most definitely too small. I used 00 welding cable when I mounting the battery in the trunk.
Re: Starter cable gage needed [Re: crackedback] #2447662
02/06/18 09:46 PM
02/06/18 09:46 PM
Mt Morris Michigan
Mt Morris Michigan
It might be 4gage. Bought 20yrs ago from summit in a battery relocate kit. Does look vety big. I have 2gage on ground side to engine block.
Re: Starter cable gage needed [Re: mopar dave] #2447675
02/06/18 10:01 PM
02/06/18 10:01 PM
Washington
Washington
Some of those kits had aluminum wire in them. Also, the strands were fairly big. IIRC there were only 6-8 strands of wire in the cable.
I had something similar and fought starting issues. The 00 welding cable solved that.
Re: Starter cable gage needed [Re: madscientist] #2447681
02/06/18 10:10 PM
02/06/18 10:10 PM
Mt Morris Michigan
Mt Morris Michigan
Never had an issue til now. BB must be lot harder to spin when hot. Not sure but i thought this CSR starter was rated at 3hp
Re: Starter cable gage needed [Re: mopar dave] #2447688
02/06/18 10:16 PM
02/06/18 10:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I don't know. Never used one. I was just making a general statement - starters are not all the same and they wear out. If it's acting like your OP description, I would suspect something is wrong with it.
Re: Starter cable gage needed [Re: CMcAllister] #2447711
02/06/18 10:37 PM
02/06/18 10:37 PM
Mt Morris Michigan
Mt Morris Michigan
Ill update the cable and half worn out battery first. Still have a factory mini i can throw in if need be.
Re: Starter cable gage needed [Re: mopar dave] #2447754
02/06/18 11:46 PM
02/06/18 11:46 PM
CA
CA
Easy test if you can access the starter, run a jumper cable from battery too starter stud. If it kicks over easier, you know what the issue is! Use anything that can upsize the size of the circuit, even 2 12ga runs of wire would help.
Upgrade both side of the circuit, ground cable is just as important as the positive side.
Most of those trunk kits use a 2ga wire. Not sure about them if they are really old. In the 80's I never used that stuff, always 1/0 or 2/0 welding cables. My stuff starts even when smoking hot while hot lapping.
Re: Starter cable gage needed [Re: crackedback] #2447843
02/07/18 02:11 AM
02/07/18 02:11 AM
Mt Morris Michigan
Mt Morris Michigan
thanks. The cable's too small and the battery is on its way out and starter is fairly new. I get to the welding shop and see what I can get.
Re: Starter cable gage needed [Re: mopar dave] #2447847
02/07/18 02:30 AM
02/07/18 02:30 AM
CA
CA
There are usually a couple different style of welding cable.
TPE and EPDM jacketed
I use EPDM as the jacket is better with oil resistance. There is also a new SGR wire that appears to be EPDM welding wire with a SAE rating.
Re: Starter cable gage needed [Re: mopar dave] #2447899
02/07/18 08:26 AM
02/07/18 08:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It all has to do with voltage drop. Length/diameter ratio vs available battery capacity. However the the starter Kicking out doesn't sound like a lack of watts to the starter. Does the starter continue to spin without being engaged to the ring gear? If so that sound more like a mechanical internal starter or alignment issue.
Doug
Re: Starter cable gage needed [Re: dvw] #2447929
02/07/18 11:27 AM
02/07/18 11:27 AM
Mt Morris Michigan
Mt Morris Michigan
Yes it does. It disengages while spinning engine and engage while i'm still on the start button, grinding on the ring gear. I know the battery is on its way out as it will no longer hold capacity after being run dead 5 times. So, i was thinking new larger cable and a new battery to start. If that doesn't do it, than i can put my old factory mini back on and try. The CSR starter is barely used.
Re: Starter cable gage needed [Re: mopar dave] #2447956
02/07/18 12:28 PM
02/07/18 12:28 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I have a suggestion, why don't you gather some data and determine what is wrong before you start replacing things?
you can do a simple (and I mean simple!) voltage drop test and know which components need to be fixed.
I helped a guy out that had changed his battery, cables and starter. After changing it all out his car still started poorly. took me about 3 mins to find he was dropping 2.2 volts thur his main battery cutoff and another .5 volt from his ground.
If you don't know where your voltage loss is occurring you are guessing.
try it! you will be surprised how easy it is. (see my sig)
https://board.moparts.org/ubbthreads/ubbt...tml#Post2342153
Joe
Without Data, you’re just another guy with an opinion.
Re: Starter cable gage needed [Re: sr4440] #2447981
02/07/18 01:14 PM
02/07/18 01:14 PM
moparx Offline
moparx  Offline
didn't monte always recommend a "floating" ground ?
beer
Re: Starter cable gage needed [Re: sr4440] #2447995
02/07/18 01:51 PM
02/07/18 01:51 PM
Mt Morris Michigan
Mt Morris Michigan
I understand what yur sayin, but i have already pin pointed part of the problem. The battery now shows 50% capacity on my charger and the cable is already known to be too small. Those parts are already needed, so why not install them and go from there? It needs those parts anyway, not like its wasted money. The starter relay is getting old as well, think i'll switch it out as well. This will be a good project as i would like a new battery box and a repaint in the truck as well. Thanks
Re: Starter cable gage needed [Re: mopar dave] #2448100
02/07/18 05:34 PM
02/07/18 05:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
What is the rating of the master switch? Does it have copper or silver contacts? How old is it? What is the voltage drop across the contacts under a high load? I have fixed multiple electrical issues by changing out old or cheap switches.
