Page 2 of 3 < 1 2 3 >
#2448713 - 02/08/18 06:18 PM Re: 6 pack metering block question [Re: mickm]
Transman Online   content
Loc: Michigan
Hope you get it resolved.
For me, I have to tell you that you are the first guy that I have heard that has a lean six pack. Most everyone I have heard of or seen has always been stink rich.
That lean stench smell I describe - I usually smell it behind old school buses. Why - don't know. shruggy
#2449167 - 02/09/18 03:10 PM Re: 6 pack metering block question [Re: Transman]
mickm Offline
Loc: California
Well remember, it's lean because they didn't drill out the idle restrictor passages! I'll see what happens when I get a correct metering block in there.
With 2 1/2 turns out to get a 15:1 idle, I assume with a properly working metering block I should be able to now set it where I want.
"the orange fun car" 540 Hemi 4 spd 3:54 dana
1 of 1 - only FK5 70 Road Runner that used to be a 383 auto now a 540 Hemi Six-Pak 4 spd in existence
#2451071 - 02/12/18 11:17 PM Re: 6 pack metering block question [Re: mickm]
70sixpkRT Offline
Loc: South San Francisco, Ca
Get yourself a Promaxx metering block. They will set it up for you.
http://promaxcarbs.bizland.com/id1.html
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
#2451088 - 02/13/18 02:01 AM Re: 6 pack metering block question [Re: 70sixpkRT]
mickm Offline
Loc: California
I would go for that, expect I want to keep the stock look. I know I'm leaving a lot of horsepower on the table by a) having the six pack in the first place, and b) not setting it up optimally, but it's the novelty I'm going for.
Once I miss the extra horsepower of my 2X4 setup, (and I do already, just not enough yet), I'll go back to that. But for now, it's just cool having an air cleaner that reads...
"HEMI Six Barrel"
#2451095 - 02/13/18 05:19 AM Re: 6 pack metering block question [Re: mickm]
Dilbert Offline
Loc: out riding & passing you
Are you going to set up the carbs properly or just wing it and then ask questions? drive
Did you know that Tom Hoover spoke very highly of a six pak on a hemi as the fuel distribution was wayyyy much better than the 2x4 set up? I thinks it's humorous with all the talk that a few ponies were left on the table with the +6 vs 2-4s or a big fat 4bbl when a drag race would confirm that six paks rule!.
Edited by Dilbert (02/13/18 05:23 AM)
#2451194 - 02/13/18 11:26 AM Re: 6 pack metering block question [Re: mickm]
70sixpkRT Offline
"HEMI Six Barrel"
You don't see the metering block with the air cleaner on.
4-speed
3:54 Dana
#2451220 - 02/13/18 12:31 PM Re: 6 pack metering block question [Re: Dilbert]
mickm Offline
Loc: California
No, I did my research first, installed them following some specific instructions I got here on the board, and now am asking questions for the small issues I'm having problems with.
That was one of the reasons I did it, was talking to Tom Hoover about it a few years ago at MATS. But first of all, that was a 426 he was talking about, not a 540. Then there is the fact that at 4bbl ratings, the six pack flows 935 cfm, where the two Edelbrocks I have flow 1300. Then there is the dual plane design of the 6 pak manifold as compared to the single plane Stage V dual 4 I use, which dyno'd by FHO produced 40 more HP than a stock manifold. And yes, setting up a set of drag 6 pak carbs with all 500 CFM carbs may put it back in the range of a single or two 4's, but probably not with that manifold. So this really is in no way and apples to apples comparison.
So yes, it is down on power, and would lose miserably on the track to my other setup.
#2451762 - 02/14/18 03:37 PM Re: 6 pack metering block question [Re: mickm]
mickm Offline
Loc: California
Ok, the conclusion to all this. Got the new metering block from Holley, same result. Probably my fault, but I reminded them, (may not have told them in the first place, thought I did), that I'm dealing with a 540, and they said, Oh, in that case there is nothing we can do for you. This is designed for a 440, and will supply it well, but we can't do or say anything about a larger displacement engine.
Called ProMax, and they said "Yep, that is what our metering blocks are designed for." He also said the six pack metering block is an odd duck, in that it doesn't have an idle restrictor passage in the usual place, which started all this.
So I live with it, or get a Promax block, as Ricky suggested.
All I wanted to do was clean up a stinky idle. I'll live with it for now...
#2451766 - 02/14/18 03:44 PM Re: 6 pack metering block question [Re: mickm]
70sixpkRT Offline
I wouldn't run too lean. You could wash out some cylinders.
4-speed
3:54 Dana
#2451783 - 02/14/18 04:14 PM Re: 6 pack metering block question [Re: mickm]
RATTRAP Offline
Loc: N/E, Michigan
Some times you can not get the carb down to the idle circuit and still have enough air to keep the car running, I drilled a small hole in each butterfly plate to allow additional air flow so the car will stay running while down on the idle circuit.
#2451808 - 02/14/18 05:04 PM Re: 6 pack metering block question [Re: mickm]
krautrock Offline
Loc: central texas
how big is the cam and what is the LSA ?
if it has alot of overlap you might be stuck with a stinky idle...
also you have three carb to adjust idle mix on?? can you richen the outboard carbs up a bit and get the center carb a little more in line with traditional settings??
Edited by krautrock (02/14/18 05:05 PM)
#2451813 - 02/14/18 05:08 PM Re: 6 pack metering block question [Re: mickm]
krautrock Offline
Loc: central texas
i guess as a test, you could always put some thin wire in the idle air bleeds, readjust idle mix to where it likes it and see if the exhaust is still stinky...
#2451836 - 02/14/18 05:57 PM Re: 6 pack metering block question [Re: mickm]
70sixpkRT Offline
"HEMI Six Barrel"
Mick if decide to pull the Sixpack off, let me know.
4-speed
3:54 Dana
#2451864 - 02/14/18 07:02 PM Re: 6 pack metering block question [Re: 70sixpkRT]
mickm Offline
Loc: California
"HEMI Six Barrel"
I'll swap manifolds one of these days, but will keep the six pak setup. No sense in getting rid of it, it's a fun novelty! But I will let you know.
#2451866 - 02/14/18 07:05 PM Re: 6 pack metering block question [Re: krautrock]
mickm Offline
Loc: California
I have it farther down, in the 14+ range, just turns the screws farther out.
I'm just going to live with it. There are other things that need attention, this is just more of a nuisance than anything else.
I didn't expect it to take this much time and energy, but since it is what it is and doesn't harm anything, it's good enough.
#2451892 - 02/14/18 07:57 PM Re: 6 pack metering block question [Re: mickm]
62maxwgn Offline
Loc: Central,PA
If you hate the stinky smell switch to 101 low lead AV gas,you'll love it then !! grin
#2451896 - 02/14/18 08:05 PM Re: 6 pack metering block question [Re: 62maxwgn]
mickm Offline
Loc: California
Is that a sarcastic "you'll love it"? Besides with what I imagine to be $7-10 / gallon prices, I'm not sure about that!
Edited by mickm (02/14/18 08:06 PM)
#2451928 - 02/14/18 09:11 PM Re: 6 pack metering block question [Re: mickm]
BSB67 Offline
Loc: Prospect, PA
If you have a large overlap cam you should be focusing on idle quality, not what an O2 meter is reading. It simply does not read right. If the O2 meter is reading 15:1 the the combustion charge AF ratio could still be far too rich. Some have reported as high as 18:1 meter reading at best idle quality w a big cam
500" NA, Eddy head, pump gas, exhaust manifold with 2 1/2 exhaust with tailpipes 4150 lbs with driver, 3.23 gear, stock converter 11.68 @ 120.2 mph
#2451929 - 02/14/18 09:14 PM Re: 6 pack metering block question [Re: mickm]
62maxwgn Offline
Loc: Central,PA
Not sarcasm,fact.All I've ever ran in my sixpack Superbird and wagon since 1992,airport is 10 mi over the mountain,$4.35 gal.
#2452006 - 02/15/18 12:46 AM Re: 6 pack metering block question [Re: 62maxwgn]
Loc: Bend,OR USA
Do you know about the Federal law restricting using leaded fuel of any type on any public U.S. roads, freeways or highways in all of the U.S.? If not be aware of it, it carries a $10,000 for the first offence work down
I can tell you that every law enforcement agency in California that I've talk to or heard about are aware of it and they know the local courts get to keep all of the fine money from that citation puke down shruggy
I was warned by a San Bernardino County sheriff about that back n the 1990s when he saw one of my old race cars with current tags at the old LACR race track, he assumed I drove it on the street regularly, which I hadn't done in his presents at that time, he was a drag racer also work The smell gives it away shruggy
25,708 Registered Members
196,858 Topics
Seat Options for 5 point harness
by Kam*Kuda
01/22/19 08:16 PM
RAM Tradesman C/V Aluminum Cargo Floor Questions (2013)
by danski0224
01/22/19 07:55 PM
lower radiator support
by plycuda
01/22/19 07:40 PM
Broadcast sheet alignment
by mopargem
01/22/19 07:39 PM
