R11 Am radio. 70 Barracuda. 3 speaker possible? #2447032
02/05/18 07:49 PM
02/05/18 07:49 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hello
Would it be possible for a 70 Barracuda equipped with a R11 AM radio to come with a 3 speaker dashpad?
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447049
02/05/18 08:25 PM
02/05/18 08:25 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
No. The 3 speaker system is stereo. The stereo radios have a left and right channels with a knob to adjust balance, also with 3 speaker wires coming out of the radio. An AM radio has 2 speaker wires coming out the radio.
Is it possible a worker made a mistake and put on a 3 speaker dash pad with an AM radio? Well yes anything is possible.
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447055
02/05/18 08:45 PM
02/05/18 08:45 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You could get an AM radio with a front and rear speaker
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447145
02/05/18 11:10 PM
02/05/18 11:10 PM
Alabama
BigMoneyLewis Offline
Alabama
Only the AM 8track and AM FM E body had the 3 speaker dash in 1970.
Along with the 3 speaker dash came a special wiring harness and crossover box as well.
Greg
gregward@mchsi.com phone 256-852-0955
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447163
02/05/18 11:39 PM
02/05/18 11:39 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
....OK so they are not SUPPOSED to come with a 3 speaker dashpad.
But, given some oddities when it comes to mopars, like missing torque boxes on HEMI cars, or HEMI fenders on cars that were not supposed to get em, etc.
Has anybody ever seen a 3 speaker dash on a car that came with an AM radio?
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447172
02/05/18 11:54 PM
02/05/18 11:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Nope.
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447189
02/06/18 12:23 AM
02/06/18 12:23 AM
Chicago
PurpleBeeper Offline
Chicago
This might just muddy the water....I "thought" that convertibles (at least b-body) got 3 speakers... BUT my car is coded for AM/8-track, so maybe I was wrong. I've never heard 3 speakers = am/fm or am/8-track
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447218
02/06/18 12:59 AM
02/06/18 12:59 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447231
02/06/18 01:13 AM
02/06/18 01:13 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 B-bodies, convertible has nothing to do with it. It depends on the radio type chosen.
IE - No radio ordered, no speaker at all. wink
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447233
02/06/18 01:16 AM
02/06/18 01:16 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
My 1970 Fury has AM / FM with the three speaker dash.
My 1970 Sport Satellite has AM / 8-track with the three speaker dash.
Both are four doors.
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447259
02/06/18 02:47 AM
02/06/18 02:47 AM
Alabama
Alabama
To elaborate a little more ,It would be impossible for a 1970 E body with AM radio to have a 3 speaker dash , because 3 speaker dashes were used only on "stereo" applications . The entire reason for 3 dash speakers was for stereo applications , which also meant that ALL AM 8tracks and AM FM E bodies had 3 speaker dashes in 1970 .
Greg
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447260
02/06/18 02:51 AM
02/06/18 02:51 AM
Alabama
Alabama
To address purplebeepers question about B bodies ... ALL 1968-70 AM 8track B bodies will have the 3 speaker dash , and ONLY the AM 8tracks , since the B body AM FM radio in 68-70 was mono only it will simply have the single 4x10 dash speaker , unless a rear speaker was ordered (N/A on the 27 body of course )
Greg
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447270
02/06/18 03:39 AM
02/06/18 03:39 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
In an E body?
ALL THE TIME
I've seen 3 speaker with an AM
I've seen 1 speaker with an AM/FM
I've seen AC pad in a non H51 car
I've seen 70 pad in a 71
I've seen 71 pad in a 70
I've seen a black 71 pad in a burnt orange interior car
I've seen Barracuda pads in Challengers and the other way around.
I've seen a /6 pad in a 440 SIXPACK car
Face it. These pads failed early and often and were changed out with the next best pad that fit.
I have NEVER seen a car with a factory incorrect installed pad. Think about it! The dash assembly is done all at once. If you use the wrong pad the parts won't work out. Much harder to mess up than a torque box.
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2447380
02/06/18 02:32 PM
02/06/18 02:32 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
Nope, and I've owned over 30 e-bodies since 1978.
1970 Dodge Challenger T/A
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2448162
02/07/18 07:40 PM
02/07/18 07:40 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The IP line would be set up for the build of the dashes and all the components and would be a sub assembly line with high senority. Likely you would work off the broadcast sheet for assembly and that is why the sheet would be on the back of the glove box.
Hemi Torque Boxes being put on some E Bodies that do not take them and some that should have them and don't is easy to understand if you have ever worked in an Automotive Plant. The Body shop is for newbies and low seniority so just keeping up with the extra parts going on like Torque Boxes and understanding the Build Sheet when you have just started would be common. Usually three days of training or less and you have to use two or more spot welders on every vehicle or chassie. Now you relying on an inspector that is ticked at you screwing up and is sick of doing your job and lets things go and just does not want to do his job of inspection or a repairman that is tired of a new employee every week or so and keeps the line running and sends it to reject for a fix that they would not do because it is just to hard to do it and would ship it with or without boxes.
1971 HEMI E BODY REGISTRY
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2448753
02/08/18 10:22 PM
02/08/18 10:22 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks for all the replies guys!!!
The thing is that I have a 70 cuda that is coded for the R11 radio.
And I just happened to find an original 70 Barracuda dash but it had the 3 speakers. Thought Id be able to use it maybe if there were those kind of screw ups at the assembly line, but since there were not, I dont think Id like to use it if my car is not coded for it.
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2448758
02/08/18 10:32 PM
02/08/18 10:32 PM
california
Mr D21 Offline
Mr D21  Offline
california
wow - so if one person says its possible you would use it??? This was a strange post to find out R11 radios and 3 speaker dashes don't line up...
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2448762
02/08/18 10:42 PM
02/08/18 10:42 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Not only one, but I sure wanted to know if it was a possibility but it clearly shows that IT IS NOT.
Its the same with torque boxes, or god knows which other things with these cars.....
I hate the way how repro dash pads look. They dont fit right, they look totally off. Repro dash pads stuck out like a sore thumb on restorations IMO. I am gonna give it some thought and maybe Ill buy the 3 speaker dash and use it, even if not correct, I would say its "more correct" than a repro dash. Maybe Ill upgrade the whole thing to an AM 8 track setup and have more fun blasting some Hendrix tunes with the nostalgic hiss and skip of the tape.
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2448779
02/08/18 11:11 PM
02/08/18 11:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Offer to trade the one you found for the one you need & see what pops up.
Re: R11 Am radio. 70 Barracuda. 3 speaker possible? [Re: domingo] #2448781
02/08/18 11:16 PM
02/08/18 11:16 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yep. Might also be a thing to do!!! Good idea.
