Rear package tray suggestions. #2447207
02/06/18 12:47 AM
02/06/18 12:47 AM
BlueRacer69 Offline OP
I would like to replace my rear package tray in my 69 Dart hardtop. I want the textured type without speaker cutouts. What manufacture makes the best fitting & most accurate looking trays now days? Also whats the best company to order it from? Thanks.
Re: Rear package tray suggestions. [Re: BlueRacer69] #2447320
02/06/18 11:51 AM
02/06/18 11:51 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I got mine from Dixie Restoration. Check with him and he should be able to answer your questions.
Re: Rear package tray suggestions. [Re: BlueRacer69] #2447324
02/06/18 12:16 PM
02/06/18 12:16 PM
New Jersey
Dartforforty Offline
New Jersey
I purchased one for my 64 Belvedere directly through Classic Industries.
Color was spot on and fit perfect with no mods needed.
Ed
Re: Rear package tray suggestions. [Re: Dartforforty] #2447341
02/06/18 12:49 PM
02/06/18 12:49 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
I would have to say that 98% of the package trays come out of REM located in REM. The texture is not as pronounced as the originals. They are not perfect, but are better than a rotten or broken one. If that is a concern, then your going to have find a good used one which can be painted to black or the desired color.
The worst part about ordering the package trays is that shipping is going to cost as much as the part. Due to the oversize nature of the part, it goes as "Oversize" in the shipping department. If your attending the Indy Cylinder Head show in March, we can bring one to that show for you to look at.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Rear package tray suggestions. [Re: 69bfan] #2447467
02/06/18 05:20 PM
02/06/18 05:20 PM
Thanks for the info guys. bow
Re: Rear package tray suggestions. [Re: BlueRacer69] #2447931
02/07/18 11:29 AM
02/07/18 11:29 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I used contact cement and glued a sheet of vinyl from the fabric store to my rough original package tray. To the untrained casual observer it would pass for original, and to be fair it looks better than the original.
Re: Rear package tray suggestions. [Re: BlueRacer69] #2447941
02/07/18 12:01 PM
02/07/18 12:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I made one out of 1/4" Cherry plywood once for a car that was not supported by the aftermarket. I painted it satin black & it turned out awesome.
