Re: Engine run test stands
[Re: Uncle Barry]
#2446777
02/05/18 12:37 PM
02/05/18 12:37 PM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
Me and my dad built one out of scrap laying around the shop about 15 years ago. Used factory motor mounts and an old 4 speed bellhousing to mount it up. Couple of toggle switches, old MSD box, old fuel pump and gas jug on the floor, some cheap gauges, etc. Very nice to have for cam break in and head retorquing. Mine aint pretty, but it works great.
[Re: Uncle Barry]
#2446780
02/05/18 12:42 PM
02/05/18 12:42 PM
Posts: 11,996 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I always pre-run/break-in my engines before I install them. And I just set them on a used truck tire with the radiator screwed to 2 2x4s. It's not pretty, but has worked for me a dozen times or more.
Master, again and still
[Re: Uncle Barry]
#2446817
02/05/18 01:30 PM
02/05/18 01:30 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
On second glance I think that engine has been photo shopped into the stand lol.
68 Barracuda Formula S 340
[Re: Uncle Barry]
#2447224
02/06/18 01:07 AM
02/06/18 01:07 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I got mine from Summit. Yeah, it cost a bit more. $500 + $100 for the gauges. But it's strong as hell, works real well, rolls around my garage easy enough, and I feel comfortable with my motors hanging off of them. I feel I got my money's worth.
[image][/image]
[Re: Uncle Barry]
#2448926
02/09/18 02:57 AM
02/09/18 02:57 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
For $219.00 the Walmart rig is really not a bad deal, comes with gauges, fuel tank, and even some engine sending units and small parts. Perfect for a spare that's for sure. Not a piller of strength but sturdy enough, I'm sure it will work just fine. Here's a working link Walmart Test Stand
[Re: Uncle Barry]
#2449049
02/09/18 12:25 PM
02/09/18 12:25 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Barry I bought some plans and started building my own because I didn't want to buy a cheap piece of crap and bandaid it to make it stronger. Mine is about 80% finished, bought gauges, and I bought a fixture off a Moparts member to mount a starter on a big block. I think I have it sold as I have been trying to clean-up some but if the deal falls through I can let you know if you are interested. It is made to fold up so you can lean it against the wall if you want to. New engine breakin bench 003 by John Cadamore, on Flickr engine stand 001 by John Cadamore, on Flickr engine stand 002 by John Cadamore, on Flickr
[Re: pittsburghracer]
#2449052
02/09/18 12:37 PM
02/09/18 12:37 PM
Posts: 3,508 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I bought a fixture off a Moparts member to mount a starter on a big block. Does anyone make something like this for a small block? Thanks, Bill
[Re: 340Cuda]
#2449062
02/09/18 01:01 PM
02/09/18 01:01 PM
Posts: 19,310 north of coder
moparx
I bought a fixture off a Moparts member to mount a starter on a big block. Does anyone make something like this for a small block? Thanks, Bill any pics showing what these adapter[s] look like ?
[Re: Uncle Barry]
#2449065
02/09/18 01:07 PM
02/09/18 01:07 PM
Posts: 4,205 New York
polyspheric
New York
w/r/t break in on a stand: the rings will only seat from combustion pressure, must be run against a load.
Boffin Emeritus
[Re: polyspheric]
#2449074
02/09/18 01:15 PM
02/09/18 01:15 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
w/r/t break in on a stand: the rings will only seat from combustion pressure, must be run against a load. I kinda like to tinker so it looked like a cool project. But I mainly did it because both Matt and I were running solid lifter cams in our engines. I figured because I take my inner springs out it would keep my old, fat butt from stretching over the fender replacing the inner springs. Now I only have one engine (my 422) with a solid lifter cam and I hope to put a roller cam in it eventually.
[Re: Uncle Barry]
#2449146
02/09/18 04:39 PM
02/09/18 04:39 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
I just used an extra k frame. I was able to make sure headers cleared everything while being able to run in the engine. I had the K frame sitting on jack stands. I bundled a radiator and box fan together and sat it in front of the engine. I used a bell housing and some scrap steel to make a panel with gauges, switch and orange box. It wasn't portable, but worked well.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Uncle Barry]
#2449299
02/09/18 10:53 PM
02/09/18 10:53 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
So what are you fellas using for a fly wheel when you run on a test stand? Would an old torque converter work?
Thanks,
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
