#2446726 - 02/05/18 07:32 AM 1970 Cuda 340 clutch
moparmatt0 Offline
Loc: NY
What is the best clutch for a mild 340 street use only thanks for the help.
#2446877 - 02/05/18 12:10 PM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
GomangoCuda Offline
Loc: N.E. Ohio
For your application I think you would like a Centerforce. Many here will agree but a few purists will insist on a Borg & Beck style.
Van Roy's Law: An Unbreakable Toy Is Useful For Breaking Other Toys.
#2446897 - 02/05/18 12:38 PM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
moparmatt0 Offline
Loc: NY
What centerforce do you recomend
#2446954 - 02/05/18 02:28 PM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
dogdays Offline
Mild 340 street use only will use a stock clutch set just fine. Why complicate things???
Rockauto is your friend in this case:
http://www.rockauto.com/en/catalog/plymouth,1970,barracuda,5.6l+340cid+v8,1496494,transmission-manual,clutch+kit,1993
Generally speaking, the diaphragm clutches have lower pedal effort than the Borg & Beck.
Here's why you don't need anything more than a stock type clutch: factory engineers were very good at matching clutches, transmissions, etc., to the engine in front of them. If you have hopped up your 340 mildly or even majorly, without a power adder the engine's torque will not increase over stock or at most, add 10%, which is well within the safety margin designed into your stock clutch. What increases the power is moving the torque peak higher in the rpm range. But it doesn't matter what horsepower your engine makes! What the clutch sees is TORQUE. So unless you use nitrous or supercharger/turbocharger the torque stays close to the same, meaning the stock clutch is adequate. The farther you go from originality, the greater the chance of reducing driveability.
BUT if you really have to spend $500, then either the Centerforce II or Dual Friction is a very nice setup which will last forever in your application.
R.
#2447201 - 02/05/18 09:41 PM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
PurpleBeeper Offline
Loc: Chicago
I will point out that years ago I bought a "stock" clutch from AutoZone & I couldn't hit the gas pedal more than about 1/3 of the way down, even while already moving, without slipping the clutch.... HORRIBLE. So don't go "ultra cheap" in my opinion and at least get a decent one.
Also, I had some bad luck recently with a Hays street/strip clutch, but I was pretty hard on it to be honest. It just didn't seem like the same quality Hays used to sell.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
#2447661 - 02/06/18 06:46 PM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
Dads426 Offline
Loc: Maryland
I used a Luk clutch and pressure plate from Rock Auto for my stock 72 340 Duster a few years ago and I'm very happy with it. You have to remove the overcenter spring and the pedal effort is low and engagement is very smooth. Luk clutches have a good reputation with the Diesel truck crowd.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
#2447713 - 02/06/18 07:44 PM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
rarefish Online   content
Loc: New York
I bought a B&B stock replacement clutch for my 69 340 Dart last summer from Rockauto and I had problems with it right out of the box. The pressure plate was set to low when assembled. The pressure plate fingers ended up hitting the damper springs in the clutch disc when the clutch pedal was pushed to the floor. It made one hell of a grinding noise.
I had to pull the whole assembly back out and return it for a refund.
I ended up buying B&B Ram "Street" Clutch #88766 from Summit Racing which worked out fine for me.
The catalog picture on Summit's web site shows a diaphragm pressure plate, but it is actually a B&B pressure plate.
#2448079 - 02/07/18 01:59 PM Re: 1970 Cuda 340 clutch [Re: rarefish]
70440+6bbl Offline
Loc: NY
I had the exact same problem with that clutch in my ‘69 340 Swinger several years back.
'68 roadrunner 438 stroker 4-spd EE1
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
#2451155 - 02/13/18 09:43 AM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
dan9 Offline
Loc: pa.
I have a McLeod in mine with no problems. It came from Passon’s.
#2451179 - 02/13/18 10:51 AM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
dvw Offline
Loc: MI, usa
I've used the Center Force in my 360 Challenger for years. Drag strip with slicks (12.50), thousands of street miles. Never slips. Never shudders. Good pedal pressure (over center spring removed, wife's car). Resonably priced. Hands down the best clutch I've used in over 40 years of hot rods.
Doug
#2451247 - 02/13/18 01:45 PM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
Sinitro Offline
Loc: So Cal
I have been running a McLeod for many years in the RR..
Originally tried a CenterForce, didn't like it pulled it out and chucked it in the dumpster...
Just my $0.02... wink
#2456481 - 02/23/18 11:05 PM Re: 1970 Cuda 340 clutch [Re: moparmatt0]
Sixgun Offline
Loc: Western Washington
Mcleod 10.95 3 roller...ceramic faced disc= awesome. I tear 'em up and these things last. Rebuildable at McLeod also. 671 HP 670 TQ and no dual disc...
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
25,741 Registered Members
192,958 Topics
trunk mat
by otter440
02/20/19 09:18 AM
Fender Installation Tips From AMD & Classic Muscle Metal
by Rustymuscle
02/20/19 07:42 AM
Congrats moparts member Goody's cuda in Mopar action
by rdrnr6970
02/20/19 05:41 AM
Monster Musclecar Weekend at Gateway Sept 13/14/2019
by SNK-EYZ
02/20/19 02:44 AM
