727 trans, what is this hole? #2446585
02/04/18 11:44 PM
02/04/18 11:44 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Hello
What is the threaded hole next to the dip stick tube for? Looks like it goes down to the pan. I was missing my dip stick tube so not sure if anything was ever in there.
Also while cleaning up the trans I found the last 4 of my sequence number hand written on the top of the case. Almost didn't see it. Never would once installed in the car.
Hole?
Sequence number
Re: 727 trans, what is this hole? [Re: njmopar] #2446590
02/04/18 11:59 PM
02/04/18 11:59 PM
A727Tflite Offline
A727Tflite  Offline
Earlier models used a dipstick held in not only by the bell housing bolt at the top but that bolt at the bottom of the dipstick tube. The bottom bolt is not required as long as you have the correct tube that places the dipstick tube o ring down in the bore like it is supposed to.
Re: 727 trans, what is this hole? [Re: njmopar] #2446591
02/05/18 12:00 AM
02/05/18 12:00 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
one of the bolts that holds the dip stick in place on Stock dip stick.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 727 trans, what is this hole? [Re: njmopar] #2446651
02/05/18 02:02 AM
02/05/18 02:02 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
It's for threading that bolt into. :-)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 727 trans, what is this hole? [Re: njmopar] #2446886
02/05/18 03:25 PM
02/05/18 03:25 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
some early dipsticks tubes had a tab welded to the base that a bolt would go through......
Re: 727 trans, what is this hole? [Re: njmopar] #2446923
02/05/18 04:13 PM
02/05/18 04:13 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I know 1967 has that hole
I know 1970 does not have that hole.
Re: 727 trans, what is this hole? [Re: njmopar] #2446976
02/05/18 06:02 PM
02/05/18 06:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Tube ends. The tab was discontinued in '69.
Re: 727 trans, what is this hole? [Re: John_Kunkel] #2447160
02/05/18 11:35 PM
02/05/18 11:35 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Thanks for the photo. Never seen one with a tab.
