Page 7 of 9 < 1 2 3 4 5 6 7 8 9 >
#2443253 - 01/30/18 01:04 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Mopar Performance single 4BBL, single plane intake manifold for a 4150 style carb, excellent used condition, part #P5153781 $500.00 (708)288-2879 Scott
#2443255 - 01/30/18 01:10 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Vintage OFFY dual quad tunnel ram for 426 HEMI nice used condition, it has had some mild port matching $250.00 (708)288-2879 Scott
#2443257 - 01/30/18 01:18 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Weiand tunnel ram type 440 SIX PACK intake manifold, excellent used condition $1350.00 (708)288-2879 Scott
#2443385 - 01/30/18 10:58 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
GTX MATT Offline
Loc: CT
440 Source Stealth Springs, Locks, and Retainers. Good replacement for Comp 911s.
$100 plus shipping
Holley 770 Street Avenger, electric choke. Worked well when removed ~1 year ago.
$200 plus shipping
Comp Cams 7442 Pushrods, Chromoly, Heat-Treated, Cup/Ball, 3/8 in. Diameter, 9.030 in. Length, never used.
$70 plus shipping
Melling M63 standard volume oil pump, never used, box is rough but pump is still in bag. No shelf wear.
$50 plus shipping
Edited by GTX MATT (01/30/18 10:58 AM)
#2443539 - 01/30/18 02:28 PM 440 Race Engine REDUCED $500.00! [Re: GTX MATT]
moparjohn Offline
Loc: N.W. INDIANA
For sale is my COMPU-FLOW RACING built 440 race engine.
Based on 30 over 440 cast 10-26-72 with side ribs.
Forged steel crank with Eagle rods and Ross pistons.
The engine is topped with standard port Indy SR heads that have been
competition ported By Compu-Flow. They flow Int 312.60 Exh 253.20 at .700 lift. There is a Mopar Performance P4532174 intake with a 2" adapter for a 4500 carb blended and port matched.
Roller cam, roller lifters roller rockers and more.
This engine ran 10.0's in a 3000lb car with 150lb driver!
It has 185 runs on it since it was freshened by Compu-Flow.
The price is $5499.99 and is located in northwest Indiana.
I have reduced the price of this engine down to $4999.99!
You can't buy the heads and intake with the hardware & porting for that!
I can help with delivery in the Midwest area!
Contact me at: moparjohn@frontier.com
Edited by moparjohn (02/18/18 08:03 PM)
#2443741 - 01/30/18 08:30 PM Comp Cams 955-16 Dual Valve Springs – New [Re: moparjohn]
Rocket Offline
Loc: CT
I have a new set of Com Cams 955-16 valve springs. I bought these for a solid roller cam but decided to use a different camshaft. Specs are as follows:
Outside Diameter of Outer Spring (in): 1.550 in.
Coil Bind Height (in): 1.230 in.
Damper Spring Included: No
Spring Rate (lbs/in): 526 lbs./in.
Inside Diameter of Outer Spring (in): 1.135 in.
Inside Diameter of Inner Spring (in): 0.812 in.
Price is $250 shipped in the lower 48 states.
Email procketrichard@hotmail.com for more information.
Edited by Rocket (01/31/18 08:18 PM)
#2443842 - 01/30/18 10:57 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
Blues_Cuda Offline
Loc: St. Louis, MO
Hemi rocker arm setup for 2" tall valve springs. Hi ratio wide pad rockers, extra long valves (NOS all 8 intakes and all 8 exhaust)
While not pictured, it also comes with modified valve covers...they were used by Ray Barton Racing
and they will need some work to get them to seal up again.
$2,500 will take the whole setup.
Please contact Tom @ 636-432-2345 for any additional questions or if you would like to purchase.
Located in St. Louis, MO.
#2443968 - 01/31/18 08:54 AM R5-P7 roller motor stuff [Re: moparts]
LSP Offline
Loc: Dallas, TX
R5-P7 roller motor stuff - all that's needed to complete is carb, pistons, rings, distributor cap/rotor.
R5 keyway bushing 4.155" bore block
Arrington P7 heads/intake
Winberg 3.280"crank
Carrillo 6.200" rods
Trend DLC coated .927" pins
Trend pushrods
Jesel .937 key lifters
Comp Cam 60mm roller cam
Jesel Mohawk complete rocker system
Jesel belt drive
Johnson HTP oil pump
Steel fabricated box oil pan
SOLD
PM here for details/questions
Edited by LSP (02/06/18 08:59 AM)
Edit Reason: SOLD
#2443987 - 01/31/18 09:22 AM Re: R5-P7 roller motor stuff [Re: moparts]
408strokerdart Offline
Loc: Out West
Indy tunnel ram for RB with 440-1 heads. Port matched to 345 CNC heads. Complete with linkage and a pair of 1050 Holley Dominators. Ready to run. $1800 OBO.
Fuel Injected Gen 3 stroker coming Spring 2018
#2444036 - 01/31/18 10:55 AM 440 EDELBROCK STR CROSSRAM INTAKE [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
440 EDELBROCK STR CROSSRAM INTAKE,VERY NICE INTAKE $1,999
*WE CAN SHIP*
E-MAIL: GDMUSCLECARPARTS@YAHOO.COM
ORANGE PARK,FL.
#2444713 - 02/01/18 01:07 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
B1Frank Offline
Loc: West Virginia
Old school aluminum fuel tank,and mounting straps..i would say #3-4 gallon tank,..on the small side $45.00 call Mike at 810 834-7408 thanks moparts !
Edited by B1Frank (02/01/18 01:08 PM)
#2445269 - 02/02/18 02:22 PM Hemi engine needs assembly [Re: moparts]
Dartforforty Offline
Loc: New Jersey
Mopar Performance Mega Block 4.5 bore. 14 to 1 compression ratio. Apart for inspection. Block needs a final touch hone before assembly. Have 8 new Arias pistons, rings, bearings. 8 Carrillo steel connecting rods. Keith Black gear drive, Keith Black billet crank 4.375 stroke. Dart heads, Keith Black valve covers. Keith Black rocker system. Engle cam 609 lift duration 320. Custom built Hogan sheet metal intake, needs plate to run carbs made.
I have paper work with all specs for serious buyer. No oil pan or oil system. No water pump housing. Comes with most bolts to assemble motor. No distributor. Comes with spark plug tubes, push rods, and fluid damper.
Motor is located in Central New Jersey. PM me through the board for contact info. $10,500.00 OBO
Edited by Dartforforty (02/03/18 06:42 PM)
#2445548 - 02/03/18 08:18 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
ts racer Offline
Loc: land of the free
New B1 TS T&D Rockers.
4 RH 1.650 .400 O/S 1.80 Ratio.
4 LH 1.650 .400 O/S 1.80 Ratio
Asking $500.00
B1 TS step headers, with SS merge collectors, O2 bungs. Coated.
Fits RJ chassis may fit others. Asking $900.00 OBO Very nice. Used a few runs.
Indy reverse Flow Plate
#2446411 - 02/04/18 04:05 PM Re: Mopar W2 rockers [Re: MGC340]
Azzkikrcuda Offline
Loc: North Dakota
Used March Performance 6-rib serpentine Water pump pulley for big block PN#10312. Powder coated black, $60 shipped PM me here if interested.
The only Carbs I care about are under the hood!
#2446435 - 02/04/18 04:43 PM CSR BIG BLOCK #836 SHIELD & BRACKET/BOLT KITS [Re: Azzkikrcuda]
moparjohn Offline
Loc: N.W. INDIANA
I have an expired and used CSR Big Block #836 transmission shield.
It has been modified for an aftermarket transmission fluid tube.
The mounting spacers and safety strap and in great shape.
Also included are new brackets and bolts!
The price is 1/4 of new at $99.00 plus shipping.
I also have a set of new brackets and bolts for $25.00 plus shipping.
If interested contact me at: moparjohn@frontier.com
Thanks!
Edited by moparjohn (02/09/18 11:40 AM)
#2446441 - 02/04/18 04:46 PM TCI RACING DEEP ALUMINUM 904 TRANSMISSION PAN [Re: moparjohn]
moparjohn Offline
Loc: N.W. INDIANA
I have an almost new TCI deep aluminum transmission pan for 904 Mopars.
Also included are 12 hex head light weight mounting bolts.
The price is $115.00 plus shipping.
Thanks!
#2446442 - 02/04/18 04:51 PM Re: Mopar W2 rockers [Re: Azzkikrcuda]
Azzkikrcuda Offline
Loc: North Dakota
New AR Engineering AR372 shear plate. Used to mount a 4150 carb on a 4500 intake. Requires 4150 carb with dual pattern baseplate. Includes gaskets. $125 Shipped PM me here if interested.
#2447402 - 02/06/18 12:14 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
brownout Offline
Loc: ca
sold
Thanks moparts
Edited by brownout (02/08/18 12:26 AM)
#2447660 - 02/06/18 06:45 PM Re: big block bronze oil pump drive [Re: JesseR]
dsd70bee Offline
Loc: oak park, il.
Original Max Wedge crossram linkage, what you see in the pictures is what I have $150.00 (708)288-2879 Scott
#2447678 - 02/06/18 07:06 PM turbo action 8” 727 converter [Re: JesseR]
JesseR Offline
Loc: Mountain City, TN
Like new, only 20 passes, $400 plus shipping
82' dodge pickup with a 499 low deck
25,142 Registered Members
186,664 Topics
Guess my Dyno numbers
by 10sec440
02/20/18 01:50 AM
Challenger urethane bumpers
by 2002bluert
02/20/18 12:57 AM
Removing Rusty Rods & Pins From Pistons...
by Clair_Davis
02/19/18 11:45 PM
Where to find a phone number without having to pay for it !!
by Stanton
02/19/18 10:40 PM
