#2445544 - 02/03/18 08:05 AM do they make like tin snips that cut backwards? scissors?
Andrewh Offline
so like a pair of scissors folded back on it self that would open facing the direction of the handel instead of away like a normal pair?
so my daughter got a mouth guard molded around her braces.
they won't come off.
I cannot bite into it from the front at all. but I could grab a bit off the back and get a pair of scissors on it and start the cut, but as I move farther up I can't get an angle on it.
I was just wondering if they made scissors that cut towards you instead of away.
waiting for the orthodontist to open.
#2445581 - 02/03/18 09:31 AM Re: do they make like tin snips that cut backwards? scissors? [Re: Andrewh]
Guitar Jones Offline
Loc: in a cattle trailer down by th...
Not that I know of but geeze, that has to suck. Sorry for your daughter.
I never learned to count my blessings, I choose instead to live inside my disasters.
The Scamp is sold, now just two old trucks and one new one.
'74 W200 Crew Cab 360, NP435, D44, D60 and NP205 divorced transfer case. Magnum 5.2 MPI and NV4500 coming soon.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi!
#2445692 - 02/03/18 01:14 PM Re: do they make like tin snips that cut backwards? scissors? [Re: Andrewh]
feets Offline
Senior Management
Loc: Irving, TX
Andy, if you had something like that you'd hurt yourself.
I'm not sure that any of my tools would work. You would likely need to cut down from the top but going very slowly so you don't get into the teeth or braces.
I'm sure it's miserable but you're better off waiting for the dentist. If it's urgent then take her to the ER.
#2445711 - 02/03/18 01:52 PM Re: do they make like tin snips that cut backwards? scissors? [Re: Andrewh]
Andrewh Offline
yeah, just waiting cause they can't see her till 5. thought I would find another way.
25,740 Registered Members
192,887 Topics
04 & 05 1500 as cheap daily driver
by 70FJ5383
47 minutes 0 seconds ago
Hellcat cuda swap.
by rattler
Today at 08:44 PM
2.15 int. Valve too big for 318 @30 over?
by roadrunninMark
Today at 07:11 PM
THE LEGEND OF SHIRLEY MULDOWNEY
by theraif
Today at 06:52 PM
