Fuel pump arm #2445533
02/03/18 10:44 AM
02/03/18 10:44 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
I see that Holley sells replacement fuel pump levers/arms for Chevy and Ford but haven't found any Mopar arms. I'd like to convert a Chevy SB high volume pump I have to BB Mopar. The pump levers looks very much the same - what's the difference between the two pumps (unfortunately I don't have a BB Mopar pump for comparison)?
Where can I get a Mopar arm?
Re: Fuel pump arm [Re: DGS] #2445568
02/03/18 11:59 AM
02/03/18 11:59 AM
VA
dragon slayer Offline
VA
I do not know what the SB Chevys are like, or the holley type. For carter you need to be careful swapping parts. Arms may look similar but tolerances in length can bind pump internally, even if the outer segment is correct. I have tried it. Carter Levers have a part number on them.
Carter also makes a high volume pump for mopar. Might be the safest way to go.
Re: Fuel pump arm [Re: DGS] #2445682
02/03/18 03:59 PM
02/03/18 03:59 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Holley used to make kits.Tried to get one for a pump I bought in th 70s and not avaliable.Just buy a new holley pump.carters i had too many problems with.Rocky
Chrysler Firepower
