Separating lower control arm from ball joint stud
#2445561
02/03/18 11:47 AM
02/03/18 11:47 AM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
What is the best way to separate the lower ball joint from the control arm without damaging the rubber seal? I don't want to use a pickle type separator. Everything is clean and painted and detailed and I don't want to scratch anything up. I need to get this separated so I can change the lower control arm bushings. Any advice is appreciated. Thanks.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: Separating lower control arm from ball joint stud
[Re: 11secaarcuda]
#2445570
02/03/18 11:59 AM
02/03/18 11:59 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
You can buy a tool to separate the joint without hurting it from harbor freight. hope this link works How to Remove a Ball Joint Safely - Harbor Freight Ball Joint ... Video for ball joint toolâ–¶ 6:46 https://www.youtube.com/watch?v=ZcCfWmrVQfMGus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 11secaarcuda]
#2445645
02/03/18 02:35 PM
02/03/18 02:35 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I've backed off the bj nut a couple of turns then used two ball peen hammers, one held with the ball end against the spindle and the other whacking the first, with the arm hanging down and the bar not backed off so the spring load helps to pop it loose. Trade places on the spindle while whacking with the hammers. I have used the pullers too which are awesome but sometimes you can't fit them in.
Carl Kessel
[Re: 11secaarcuda]
#2445657
02/03/18 02:58 PM
02/03/18 02:58 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I have also unbolted the balljoint from the spindle, then you can remove the control arm with the balljoint still attached. Just an alternative.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: 11secaarcuda]
#2445679
02/03/18 03:57 PM
02/03/18 03:57 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Hammers always wok for me.Even at the shop i used them and did probally thousands.Just leave the nut on a few threads.Only had to use my fork a few times in 40 years.Rocky
Chrysler Firepower
[Re: 11secaarcuda]
#2445844
02/03/18 08:31 PM
02/03/18 08:31 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Gotta love Moparts answers.
Beat on it with a hammer.
No, beat on it with an AIR hammer.
let's put a steam roller on it.
Maybe some C4.
How about we just torch it and call it a day.
[Re: 11secaarcuda]
#2445953
02/03/18 11:58 PM
02/03/18 11:58 PM
therocks
Niles , Ohio
Well using a hammer was done for decades and still is.Not everyone has a show car and worried about hitting a arm with a hammer or air hammer.Rocky
Chrysler Firepower
[Re: moparx]
#2446189
02/04/18 01:44 PM
02/04/18 01:44 PM
Supercuda
About to go away
About to go away
up yours
and just SOMETIMES, you WILL damage the paint because there is NO WAY to prevent that from happening when disassembling certain components no matter HOW CAREFUL you try to be. it's the nature of the beast [as some would say]. As the Doc said I have also unbolted the balljoint from the spindle, then you can remove the control arm with the balljoint still attached. Just an alternative.
[Re: rumblebee4232]
#2447291
02/06/18 09:02 AM
02/06/18 09:02 AM
11secaarcuda
WASHINGTON, PA
Thanks guys for all the suggestions. I'll get either the Harbor Freight tool, or the tools from Mancini
