Indy oil pump and Milodon cover #2444591
02/01/18 01:15 PM
02/01/18 01:15 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Will an Indy oil pump work with a Milodon pump cover/spin on adapter ?
I already have the Milodon pump cover.
Thanks, Don
Re: Indy oil pump and Milodon cover [Re: cudadon] #2444636
02/01/18 02:20 PM
02/01/18 02:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My Indy pump is just a high volume stocker with the Indy cover.
Doug
Re: Indy oil pump and Milodon cover [Re: cudadon] #2444653
02/01/18 02:39 PM
02/01/18 02:39 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The new milodon billet pump 21814 is the way to go with the one piece billet cover either 21205 or the 21215 depending on where you want the port inlet
Re: Indy oil pump and Milodon cover [Re: cudadon] #2444664
02/01/18 02:54 PM
02/01/18 02:54 PM
AndyF Online content
AndyF  Online Content
Thanks, Don
Yes
Re: Indy oil pump and Milodon cover [Re: dvw] #2445146
02/02/18 12:27 PM
02/02/18 12:27 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Doug
Doug is the Indy pump aluminum?
I was going to add my milodon cover to a meling hv pump and the filter adapter hits the pump body. It doesn't allow the bolt holes to line up.
I want to prime and turn over my spare 451 that has ext. oil pick up.
Thanks for your help, Don
Re: Indy oil pump and Milodon cover [Re: cudadon] #2445190
02/02/18 01:57 PM
02/02/18 01:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No, only the cover and the filter adapter. I believe the base pump is a Mellen high volume. Works great. 60 psi (@150 oiltemp) idle/70 psi@7000 with .003 rod/.004 main clearance.
Doug
Re: Indy oil pump and Milodon cover [Re: dvw] #2445640
02/03/18 02:29 PM
02/03/18 02:29 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Not what I expected. Of course you only see the aluminum parts.
Maybe I will take a die grinder to the cast iron Melling pump to make the cover fit?
Sounds like it is the same as buying an Indy pump. Pump only.
Doug thanks for your help.
Don
Re: Indy oil pump and Milodon cover [Re: AndyF] #2445641
02/03/18 02:29 PM
02/03/18 02:29 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Thanks, Don
Yes
Thanks Andy.
