#2426549 - 12/31/17 03:13 PM Mopar Transmission Wanted - 1st Quarter
moparts Offline
#2426760 - 12/31/17 07:32 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
440mopar Offline
Loc: USA
1967 big block 727 trans. #2801541 with factory torque converter.
fourfortymopar at yahoo.com
#2426867 - 12/31/17 09:35 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Wanted; Big block 727 transmission with part of #3515848. I would also consider part #3410670 or #3515846. Prefer if in the Detroit area for pickup so as to avoid having to ship.
A new or good used Turbo Action or TCI ten inch torque converter for a 727 with a stall rating of 3300-3500 rpm.
Complete factory automatic kickdown linkage set-up for a 67-69 big block A-body.
gt340 @ yahoo.com
#2427989 - 01/02/18 06:47 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
5carguy Offline
Loc: Lee Co. Fla.
I'm looking for the 4 OEM bolts and washers that hold the 4 speed trans to the bellhousing.71 E body.
PM here
Thanks Moparts FOUND SOME Thanks
Edited by 5carguy (01/14/18 05:42 PM)
#2429635 - 01/05/18 06:45 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
cudaman1969 Offline
Loc: fredericksburg,va
1969 auto trans, last three digits are 093 for RR-Super Bee & RT and GTX. 383-440, Dec-Feb build date, others dates will be considered. If just the case, that will be fine, I have the guts.
I have an 091, could do a trade or sell.
PM here
Edited by cudaman1969 (01/05/18 06:46 PM)
#2430722 - 01/07/18 06:22 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
STEFF Offline
Loc: Smyrna, South Carolina
Reverse Pattern Manual Valve Body for 727 wanted.
PM or Email
Srrimay@gmail.com
#2431965 - 01/09/18 09:21 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
biff426 Offline
Loc: Delaware
Looking for a built small block 727 or Turbo 400 with small block ultra bell. Prefer something with a brake.
Pm me here or dwmotorsports1@gmail.com
#2433194 - 01/11/18 11:09 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
Tommy383 Offline
Loc: NC
Looking for a 727 to mate with my 512rb.
Wanting something I can drive on street. Estimated power in the 650-700 range.
Let me know what you have. Located in Nashville.
Possible trade with keisler tko600 kit for b body. ( plus cash on 727 end)
#2436615 - 01/17/18 08:16 PM Hurst Ram Rod Shifter Boot Wanted [Re: moparts]
blewbyu Offline
Loc: Florida
I need a shifter boot for a Ram Rod Shifter. It is different then the Vertigate so see picture. Anyone with one please contact. blewbyu2bad@aol.com
Edited by blewbyu (01/17/18 08:17 PM)
#2436647 - 01/17/18 09:20 PM Re: Hurst Ram Rod Shifter Boot Wanted [Re: moparts]
moparhotrods Offline
Loc: New Castle,DELAWARE
I'm looking for a 65 - 66 slant 6 cast iron bellhousing
the casting number on the bellhousing will be
2468 431
2468 433
if you have one of these I am interested in buying it please let me know what you have thank you
#2438896 - 01/22/18 07:26 AM Re: Hurst Ram Rod Shifter Boot Wanted [Re: moparts]
RAH Offline
Loc: sw chicago
wanted J 2801544 or PK 2801544 transmissions bob h 708 687 1187
RAH@wowway.com
#2439079 - 01/22/18 01:30 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
csmopar Offline
Loc: usa
Looking for a big block pushbutton 727. Must be a 1964 or a year that is compatible with 1964. Preferably located in the mid-west or at least be willing to ship on my dime. Transmission can be a core unit as i'll rebuild it regardless. Just needs to be complete.
pm me thru here.
Got a couple now, thanks Moparts
Edited by csmopar (02/16/18 10:16 AM)
#2439467 - 01/23/18 08:47 AM Re: Mopar Transmission Wanted - 1st Quarter [Re: csmopar]
Charger446 Offline
Loc: Northeast MA
Looking for a 4 speed shifter ball for a 1969 Dodge. Looking for a woodgrain type in used condition with the grains wearing off as I want to have it match the patina on my steering wheel.
Thanks!
#2441152 - 01/26/18 04:34 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
68LAR Offline
Loc: South Park, Pa.
Looking for a 7290, 30 spline slip yoke.
Contact me here on MOPARTS or "E" mail me at LMForgacs@gmail.com
#2443112 - 01/29/18 08:11 PM 727 Lower/Rear Clutch Drum - 4-Disc Wanted [Re: moparts]
vinnyd76 Offline
Loc: Macomb, MI
I'm looking for a low/rear clutch drum (direct drive) for a small block 727 trans. 4-disc clutch drum with input shaft. Please PM me if you have one available for sale.
Vinny
Edited by vinnyd76 (01/29/18 09:12 PM)
#2443661 - 01/30/18 06:11 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
mrrandyj Offline
Loc: CT
Wanted: 727 take out outer sprag rings. These would be removed to install a bolt in sprag, or a 16 roller Ultimate or Super sprag. If you have any sitting around please let me know. mrrandyj@aol.com
Thanks!
#2450241 - 02/11/18 04:47 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
DBCooper Offline
Loc: South Louisiana
WANTED I am looking for a light weight aluminum 727 rear drum and rollerized planetary gears
Thanks !!
#2452531 - 02/16/18 10:35 AM 1970 18 spline trans [Re: DBCooper]
ogopogo Offline
Loc: BC Canada
1970 18 spline hemi 4 speed trans wanted,ideally with a ST lewis VIN on it IE 0G123456
ogopogo69 'at" shaw.ca
25,141 Registered Members
186,637 Topics
Stephens Performance will be at The Indy Cylinder Head Swap
by dsd70bee
02/19/18 12:27 PM
71 GTX Door Stainless Molding Clips ??????
by FY1TA
02/19/18 12:15 PM
Collector intake update new best
by WHITEDART
02/19/18 12:05 PM
Question for Machinists...
by Orange_Crush
02/19/18 11:50 AM
