pushrod time #244341
03/05/09 08:00 PM
03/05/09 08:00 PM
U.S.
moparniac Offline OP
U.S.
my measurement is 9.5 on indy ez heads. is that sound about right cause thats what im getting ??? thought indy were longer than that...
what pushrods do you recomend for the ez also... full MCH cnc port etc...
Mopar Performance
Re: pushrod time [Re: moparniac] #244342
03/05/09 08:18 PM
03/05/09 08:18 PM
U.S.
U.S.
9.5 is the total length..
Mopar Performance
Re: pushrod time [Re: moparniac] #244343
03/05/09 08:28 PM
03/05/09 08:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Use a pushrod checked and find out... make sure your
adjusters are set correctly before you check the length
Re: pushrod time [Re: MR_P_BODY] #244344
03/06/09 02:09 AM
03/06/09 02:09 AM
U.S.
U.S.
I used a comp cams pushrod checker and #1 was at TDC and length checked was with lash set...... I jkust thought indy were like 9.800 range ???
Mopar Performance
Re: pushrod time [Re: moparniac] #244345
03/06/09 01:12 PM
03/06/09 01:12 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Hydraulic or solid??
Re: pushrod time [Re: Dodgem] #244346
03/06/09 03:45 PM
03/06/09 03:45 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
On my RB solid roller. EZ heads, 829-16 comp lifters, 0.040" head gasket, comp promagnum roller rockers lash 0.020", I used Smith bros. ball/ball 3/8" PR's 9.65" long.
Re: pushrod time [Re: cudarex] #244347
03/06/09 04:17 PM
03/06/09 04:17 PM
U.S.
U.S.
I have a solid roller cam and .040 gaskets...
Mopar Performance
Re: pushrod time [Re: moparniac] #244348
03/07/09 04:12 AM
03/07/09 04:12 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Wedgeomatic, PM me your email address if you would like a scan of Indy's pushrod checking instructions. I am just getting ready to do the same thing for my -1 build. Beep
Re: pushrod time [Re: moparniac] #244349
03/07/09 01:57 PM
03/07/09 01:57 PM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
Wedge, i have the ez 295's and run a 45 thou head gasket. The block has been decked 2x and i run the smith bros ball/cup. the ball is a 5/32 which was real important in measuring for the overall length. I ended up with a 9.690 overall length. i don't think the comp pushrod length checker has a 5/32 ball on the end Another point, if you are running the supplied rocker assembly from Indy their instructions differ from the typical 2 thread count on the adjuster.
Oh yeah, solid roller with the comp 829 lifters!!
Let us know what you end up with.
Re: pushrod time [Re: Plumcrazyracing] #244350
03/08/09 08:42 PM
03/08/09 08:42 PM
U.S.
U.S.
did you get your measurements measuring with the rocker adjuster with no threads showing ???
Mopar Performance
