440 Source main stud girdle
#2442277
01/28/18 03:59 PM
01/28/18 03:59 PM
Posts: 108 Wisconsin
MagnumExpress
Wisconsin
Any thoughts good or bad?
#9 in the world. 2006 IHRA Super Rod 2010 IHRA Div.5 Hot Rod Champion
Re: 440 Source main stud girdle
[Re: MagnumExpress]
#2442412
01/28/18 08:19 PM
01/28/18 08:19 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I do have the 440 source girdle kit on this new build that is going together right now. A good friend of mine is also building a bb stroker snd he got the Bcr kit. It is much , much beefier and very well designed. If i wasnt so far along, i would have switched to the bcr kit. It is 1/2” vs 1/4” thick i believe.
Im sure the 440 source will help somewhat with capwalk, but the Bcr kit is much, much more rigid.
[Re: MagnumExpress]
#2442504
01/28/18 10:17 PM
01/28/18 10:17 PM
Posts: 43,095 Bend,OR USA
Cab_Burge
I am going to tell you to not waste your money on a girdle, the stock RB blocks fatal main weakness is the webbing between the bottom of the cylinders and the main bosses, take a hard look their to see what I'm concerned over. All the stock 400 blocks are a lot thicker between the bottom cylinder walls and the main webbing None of the other B or RB blocks have the thicker main webbing in them like all the 400 do My message is if you want to build a strong stock block race motor or any other pump gas motor with 600+ HP start with a good 400 block that is sonic tested first and then go from there I have seen 3 440 blocks and one 426 M.W. block that had cracks in the main webbing between the #1 and #3 cylinder going between the bottom of the cylinders and the main bolt bosses On the 400 blocks that I am going to build that sonic test well that will exceed 600+ HP I do replace the stock main caps with billet aluminum caps and ARP main studs Above 850 HP buy a new race block IHTHs
[Re: Dave Hall]
#2442538
01/28/18 11:25 PM
01/28/18 11:25 PM
Chargerfan68
New York, USA
The girdle is not a waste on an RB block. I have the same '72 block that ran without a girdle and you could see the cap squirm when removing the main caps. The girdle takes that away and I have been running near 700hp on the track for nearly 14 years with the same block. Just curious: are you talking about a 440 or 400 block? Im using the girdle just for additional peace of mind. I installed on a 400 block.
[Re: MagnumExpress]
#2442546
01/28/18 11:37 PM
01/28/18 11:37 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I put a source on my 511. Nice piece. Won’t really know how it’s doing until I pull the motor down for a freshen up. [img] https://flic.kr/p/23iMAFo[/img]
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: MagnumExpress]
#2442559
01/29/18 12:08 AM
01/29/18 12:08 AM
MagnumExpress
Wisconsin
I think after looking at both I am going to purchase the BRC part if it will work with my oil pan. I don’t know if the thickness matters a whole bunch, but the BRC definitely attaches to the block better.
[Re: Dave Hall]
#2442561
01/29/18 12:09 AM
01/29/18 12:09 AM
Cab_Burge
What main caps are you using on this build?
[Re: MagnumExpress]
#2442572
01/29/18 12:20 AM
01/29/18 12:20 AM
Posts: 2,037 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I think after looking at both I am going to purchase the BRC part if it will work with my oil pan. I don’t know if the thickness matters a whole bunch, but the BRC definitely attaches to the block better. I had the same concerns as I run a Milodon Super Stock pan with the tie rod passing through the pan. Turned out to be a non-issue. Brian
[Re: MagnumExpress]
#2442577
01/29/18 12:29 AM
01/29/18 12:29 AM
MagnumExpress
Wisconsin
I have been running this same combo for many years. It has stock main caps. I am running a Charlie’s dragster pan with a kick out on right side. Adding a little more power and want some insurance.
[Re: MagnumExpress]
#2442703
01/29/18 03:37 AM
01/29/18 03:37 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I put a BCR girdle, aluminum caps and ARP studs on my 440 about 9 years ago, after about 1,500 1/4 mile hits it was refreshed. I found 0 cap walk and the main bearings were re-used. The BCR piece is the best out there.
[Re: Jerry]
#2443126
01/29/18 11:41 PM
01/29/18 11:41 PM
dartman366
Mt. Vernon, Ohio
The cost to deck the bottom of the block is really negligible usually around $100.00, our girdle interfaces with the caps to help hold them down, so you are not relying on just the main studs to hold them in place.
also our oil pan studs have counter bored holes in the girdle so you can bolt the girdle down tight to the block. then if you want use a gasket between the girdle and oil pan. some guys will cut a rubber gasket and install that so they drop the pan and inspect it as needed. this way you don't have to bother the main caps or the girdle.
plus we don't use longer studs to secure girdle to the caps. we use a secondary set of 3/8 bolts to hold the caps to the girdle. this eliminates double stretching the main stud. we also secure the #1 and #5 cap to the girdle with an inboard set of 3/8 studs. good design and accurate machine work, I was impressed with mine.
[Re: MagnumExpress]
#2443140
01/30/18 12:05 AM
01/30/18 12:05 AM
Chargerfan68
New York, USA
Yes, my friends block is at the machine shop right now and i saw the setup after the whole setup was milled ans installed. It is impressive. I will purchase this kit for the next build for sure.
