17 inch to 20 inch wheels #2441196
01/26/18 09:13 PM
01/26/18 09:13 PM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
I have a 2016 Express with 17 inch wheels. I have a opportunity to get a set of 20 inch wheels that were an option on this truck. What will I have to do so the the speedometer and odometer will work properly?
Raul
Re: 17 inch to 20 inch wheels [Re: Aspen7695] #2441232
01/26/18 10:31 PM
01/26/18 10:31 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Absolutely nothing so long as the tire is the same outside diameter.
It isn't the rim but the tire height that would effect the speedo...
I have mechanical Aptitude.
I can screw up anything.
Re: 17 inch to 20 inch wheels [Re: bboogieart] #2441376
01/27/18 03:25 AM
01/27/18 03:25 AM
Gilbert, AZ
Gilbert, AZ
Sorry, I should have mentioned that the 20 inch tire is a lot taller than a 17 inch tire.
Raul
Re: 17 inch to 20 inch wheels [Re: Aspen7695] #2441591
01/27/18 04:55 PM
01/27/18 04:55 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Are you sure they are a lot different? I changed the 17's to 20's on my 15 and there wasn't a big difference in circumference. The speed went from reading 2% slow to reading about 1% fast. When it is showing 60MPH the truck is actually doing about 61MPH according to radar anyway.
Sheldon
Re: 17 inch to 20 inch wheels [Re: Aspen7695] #2441633
01/27/18 06:04 PM
01/27/18 06:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It is easy for someone with a real scan tool to reprogram it. I am not talking the little code readers but a real scanner like my mac mentor or snap on solus or the one the dealer has. If you were in my neck of the woods I wouldn't even charge for it because it's so easy.
Re: 17 inch to 20 inch wheels [Re: HotRodDave] #2444941
02/01/18 11:41 PM
02/01/18 11:41 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
OK so we are looking at a tire diameter change, (29 or 32 or 40?) it doesn't really matter...
You can reprogram as stated above, or do it the way I do....
Put the new wheels & tires on and have a friend with a cell phone follow you. They can then make sure you are traveling a specific speed. Test it on the highway and in the city at slower speeds.
Now it's just math.
The speedo is "X" m.p.h. off.
Not as precise as the above but will give you real world accuracy.
Drive accordingly.
Re: 17 inch to 20 inch wheels [Re: Aspen7695] #2445224
02/02/18 03:27 PM
02/02/18 03:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the problem doing it that way is you have to figure a percentage off not just X MPH as it will be different at every speed. Its good math excercise for your brain though.
Re: 17 inch to 20 inch wheels [Re: HotRodDave] #2445595
02/03/18 12:59 PM
02/03/18 12:59 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Good stuff.
Didn't know that. shruggy
Hurts my brain thinking about it. whistling
