Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!!
[Re: AeroMonte]
#2440773
01/25/18 11:34 PM
01/25/18 11:34 PM
Posts: 164 Harrisville,PA
GRAYBO
Harrisville,PA
I have a pic of the 71 Cuda I'm doing with the floor cut for the 6 speed swap. It's to big to post here though. I've put a Hellcat engine in the one I'm doing. Could you send it to my email? Graybo@zoominternet.net. would be greatly appreciated. Thanks.
[Re: GoodysGotaCuda]
#2440822
01/26/18 01:40 AM
01/26/18 01:40 AM
GRAYBO
Harrisville,PA
Back through the torsion bar crossmember needs to be removed. The 6spd swap is not even close to a bolt-in swap on an ebody... goodys, you got any pics or advise? Thanks
[Re: GRAYBO]
#2440840
01/26/18 02:32 AM
01/26/18 02:32 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I haven't got that far on mine yet or I'd post pics. Seems photobucket has killed off all the threads with pics of installs. I saw lots of pics on one of the e-body sights if your a member there... not sure if I can post links to other sites.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: GRAYBO]
#2440847
01/26/18 02:56 AM
01/26/18 02:56 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Back through the torsion bar crossmember needs to be removed. The 6spd swap is not even close to a bolt-in swap on an ebody... goodys, you got any pics or advise? Thanks I don't have many "good" pictures, just some sporadic in-process ones. I kept the torsion bars on my car, so I needed some good structure there. My torsion bar crossmember has the new upper support and what stock crossmember that was left was boxed. I added a new fore/aft frame member as well to help scatter some t-bar load toward the front. Mine is a T56 Magnum, similar enough to the TR6060 you are probably playing with.
[Re: GRAYBO]
#2450773
02/12/18 05:59 PM
02/12/18 05:59 PM
Posts: 543 Indiana, Just Off I-70
BradD
I raised the tunnel 1" in a 70 Road Runner for a Gen2 Hemi and a Magnum 6 Spd.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: GRAYBO]
#2450844
02/12/18 07:58 PM
02/12/18 07:58 PM
Posts: 361 Canada
onig
Canada
I like your homemade rotisserie.
69 Dart
