Welding Dana 60 axle tubes #2440508
01/25/18 01:03 PM
01/25/18 01:03 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
What is your preferred method of welding the axle tubes? Some say stick arc with 7018 rod, others say tig with er-70 rod, some say just mig it er-70 wire. Most say to preheat the carrier some.
Re: Welding Dana 60 axle tubes [Re: farmboy] #2440539
01/25/18 01:59 PM
01/25/18 01:59 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I tig mine
Re: Welding Dana 60 axle tubes [Re: farmboy] #2440595
01/25/18 04:08 PM
01/25/18 04:08 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I stick welded mine back in 1975
Re: Welding Dana 60 axle tubes [Re: farmboy] #2440602
01/25/18 04:21 PM
01/25/18 04:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Tig with ER70-S2. Clean it and then clean it some more. Use a torch to heat the joint and remove any remaining oil and contaminants. Heat the center section and keep it warm. Weld some, heat, weld some, heat. When it's done, use the heat to keep it warm and let it cool down gradually.
Re: Welding Dana 60 axle tubes [Re: farmboy] #2440710
01/25/18 07:54 PM
01/25/18 07:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Did mine with a Mig. Do heat the section to burn out any oil between the housing and tubes. Been this way 5 years, 500 passes, 60ft as quick as 1.240
Doug
Re: Welding Dana 60 axle tubes [Re: farmboy] #2440728
01/25/18 09:33 PM
01/25/18 09:33 PM
New York
polyspheric Offline
polyspheric  Offline
New York
All good.
Shim it into the jig, and let it cool down there.
Weld in opposing spots as if torquing wheel lugs: 12 o'clock, then 6, then 11, then 5 (not in clock rotation).
Boffin Emeritus
Re: Welding Dana 60 axle tubes [Re: farmboy] #2440738
01/25/18 09:53 PM
01/25/18 09:53 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Get it hot tanked first, then you need a welder that puts out a lot of heat. Any of the 70 series rods and filler will work, it just depends on what you are comfortable with. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Welding Dana 60 axle tubes [Re: astjp2] #2440947
01/26/18 12:54 PM
01/26/18 12:54 PM
moparx Online content
moparx  Online Content
i have only narrowed a few rears, but when the housing and brackets are done, i use a 2" diameter ground bar with steel pucks. 2 of which are bolted to the gear center bearing location. these have a .0015 id clearance for the bar to pass through. then the other 2 at the axle bearing location. they have .001 id clearance for the bar, and .002 od clearance for the bearing bore. i chain the housing to a piece of 12" I beam that has a very thick web and flanges. i test the axle bearing pucks for a super easy "slide in" fit with the round bar installed. if they don't just "flick" in using just tiny finger motion, i heat the housing and use a bottle jack to apply pressure to move the tube in the desired direction. let the tube cool, then try the puck. repeat as necessary until i have the puck fit to my satisfaction. let cool over night, then try puck fitment again. if satisfactory, then assemble rear and install. never had any tire wear, or tracking issues, doing this way of insuring housing was straight.
beer
Re: Welding Dana 60 axle tubes [Re: farmboy] #2441702
01/27/18 08:41 PM
01/27/18 08:41 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Thanks for the help, Think I will preheat and tig. Any particular reason to use -2 instead of -6 rod?
Re: Welding Dana 60 axle tubes [Re: farmboy] #2441738
01/27/18 10:17 PM
01/27/18 10:17 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Watch for the tubes pulling.
Mine moved quite a bit tig welding them.
Re: Welding Dana 60 axle tubes [Re: farmboy] #2442239
01/28/18 02:44 PM
01/28/18 02:44 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Tig welded many narrowed Danas and 12 bolts with nickle arc rod. Knock the flux off it and welded continuous around tube. Did the same as everyone else: grind the cast and the tube, preheat to burn out contaminants, and had it jigged with alignment bar. Let completely cool before removing bar. You can check your final alignment with how easy the pucks slide in and out of the housing ends. Nickle rod is designed for dissimilar metals. Good luck
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
Re: Welding Dana 60 axle tubes [Re: GTX5877] #2442384
01/28/18 07:04 PM
01/28/18 07:04 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I stick weld mine with 7018 rod and alternate right to left tube twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Welding Dana 60 axle tubes [Re: fourgearsavoy] #2442560
01/29/18 12:08 AM
01/29/18 12:08 AM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
I haven't welded the ends on yet, so I can straighten things out after all the welding is done.
Re: Welding Dana 60 axle tubes [Re: farmboy] #2447069
02/05/18 09:26 PM
02/05/18 09:26 PM
dogdays Offline
dogdays  Offline
You don't need nickel rod to weld a steel tube to a cast steel housing. A cast iron housing, yes. But the Dana is supposed to be cast steel.
R.
Re: Welding Dana 60 axle tubes [Re: farmboy] #2447238
02/06/18 01:36 AM
02/06/18 01:36 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
-2 is typically used in TIG welding where the material is or should be very clean. -6 is usually used for MIG wire but is available in precut TIG wire also. -6 has a higher silicon content which helps pull impurities from the puddle when the material is slightly contaminated. Other than that they are pretty much the same. Some people like the -6 for TIGing. I use -2 since it is the most widely recommended for clean 4130 which is usually what I do. I don't do much "dirty" stuff.
I would check the tubes with an alignment tool before welding it up, just to verify the thing is not bent before you do anything. While you can put the ends on to match the differential centerline, if they are way off, it creates all kinds of other goofy problems with the wheelbase being moved, etc. Mostly on sheetmetal housings, but I would still look at it.
Re: Welding Dana 60 axle tubes [Re: farmboy] #2447714
02/06/18 10:46 PM
02/06/18 10:46 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I did a dana 60 for my truck 20 years ago used 8011 for the root and then used 7014 with the final pass, worked perfect
