manual box stock to fast ratio #2439898
01/24/18 07:50 AM
01/24/18 07:50 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
I want to replace my stock manual steering box for a fast ratio 16:1 box.
Do I have to replace the pit arm when going for a fast ratio box?
Rockauto sells them for 285 dollars.
Re: manual box stock to fast ratio [Re: dickdale] #2439930
01/24/18 11:16 AM
01/24/18 11:16 AM
Connecticut, USA
MRGTX Offline
MRGTX  Offline
Connecticut, USA
I hope someone corrects me if I'm wrong but the pitman arm is the same but you can alter the ratio further with a different idler/pitman arm designed to do so.
Mancini Racing offers a kit to go down to 12:1
http://www.manciniracing.com/ho66moqu12ra.html
Re: manual box stock to fast ratio [Re: dickdale] #2440138
01/24/18 05:32 PM
01/24/18 05:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Don't have to replace pitman as long as new box is same spline diameter as your existing pitman.
Re: manual box stock to fast ratio [Re: dickdale] #2440348
01/25/18 01:40 AM
01/25/18 01:40 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
What would the ratio be if you used this kit with a 24:1 box?
A new iron curtain drawn across the 49th parallel
