#2439898 - 01/24/18 04:50 AM manual box stock to fast ratio
dickdale Offline
Loc: The Netherlands, OV
I want to replace my stock manual steering box for a fast ratio 16:1 box.
Do I have to replace the pit arm when going for a fast ratio box?
Rockauto sells them for 285 dollars.
#2439930 - 01/24/18 08:16 AM Re: manual box stock to fast ratio [Re: dickdale]
MRGTX Offline
Loc: Connecticut, USA
I hope someone corrects me if I'm wrong but the pitman arm is the same but you can alter the ratio further with a different idler/pitman arm designed to do so.
Mancini Racing offers a kit to go down to 12:1
http://www.manciniracing.com/ho66moqu12ra.html
#2440138 - 01/24/18 02:32 PM Re: manual box stock to fast ratio [Re: dickdale]
autoxcuda Offline
Loc: So Cal
Don't have to replace pitman as long as new box is same spline diameter as your existing pitman.
Spring Fling 33
April 13 & 14, 2019
Woodley Park, Van Nuys CA
www.cpwclub.com
500+ show cars, 200+ swap, manf. midways
Malibu Cruise, Cruise-In
Free Spectator Admission!
#2440348 - 01/24/18 10:40 PM Re: manual box stock to fast ratio [Re: dickdale]
67autocross Offline
Loc: Manitoba Canada
What would the ratio be if you used this kit with a 24:1 box?
A new iron curtain drawn across the 49th parallel
25,708 Registered Members
196,868 Topics
Solar battery tender
by 540challenger
01/23/19 08:31 AM
Fast / 6
by bigdad
01/23/19 08:09 AM
Buy A VIN?
by EV2Bird
01/23/19 07:30 AM
Is the Government shutdown effecting you? (No politics)
by MI_Custumz
01/23/19 06:40 AM
