99 Caravan gauge problem??? #243962
03/05/09 11:55 AM
03/05/09 11:55 AM
St Paul MN
73swinger Offline OP
St Paul MN
99 Caravan, the dash gauges(water temp.,tach.,speedo,gas,odemeter, & gear display) go out intermittently, and ABS light comes on. so far they come back in 5 to 20 minutes, or when you shut van off & restart.
Any ideas on the cause of this?????
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: 99 Caravan gauge problem??? [Re: 73swinger] #243963
03/05/09 09:01 PM
03/05/09 09:01 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Disconnect the battery for a few minutes and then try again...these bcm's are bugging out...
Re: 99 Caravan gauge problem??? [Re: 73swinger] #243964
03/05/09 11:17 PM
03/05/09 11:17 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
As "caveman-ish" as it sounds, our 98 did that for a bit. I would whack the top of the cluster, did this several times, now it's fine !!
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 99 Caravan gauge problem??? [Re: Magnumguy] #243965
03/06/09 02:31 AM
03/06/09 02:31 AM
Darien Center, NY
440Bel2 Offline
440Bel2  Offline
Darien Center, NY
My '98 Caravan would lose all the guages and set the check engine light. Apparantely, the solder breaks on the pins on the cluster causing this. Went to the local pick a part for a cluster and no problem since.
Re: 99 Caravan gauge problem??? [Re: 440Bel2] #243966
03/06/09 07:39 AM
03/06/09 07:39 AM
Grand Rapids, MI
Jim L Offline
super street
Jim L  Offline
super street
Grand Rapids, MI
Pull the IC and you can look at the back of the plug on the IC, if you are handy with a soldering gun its easy to fix.
Re: 99 Caravan gauge problem??? [Re: Jim L] #243967
03/06/09 09:37 AM
03/06/09 09:37 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
And..... if your's doesn't have the tach, get one that does. Plug and play. No changes.
Re: 99 Caravan gauge problem??? [Re: Magnumguy] #243968
03/06/09 10:59 AM
03/06/09 10:59 AM
St Paul MN
St Paul MN
Thanks Moparts, I'll check all things mentioned.
