Page 2 of 2 < 1 2
#2437637 - 01/19/18 05:14 PM Re: 1.06" or 1.12" FF Torsion Bars, Street [Re: YO7_A66]
TC@HP2 Offline
Loc: Pikes Peak Country
Originally Posted By YO7_A66
After I started this thread, I contacted FF for their suggestion. FF suggested the 1.06" for spirited driving and ride compromise. FF said that the 1.12" are for racing and might be too harsh on a street car.
Firm Feel deals with a fairly broad cross section of the hobby and have raced their cars in the past. I would tend to put a pretty large chunk of faith in their recommendation. I know Mitch runs the biggest bar possible and is very happy with it. As racer, his butt dyno may be calibrated slightly different than others on here who I've seen complain that .92 are too harsh. Unfortunately there is no universal measure of harshness of ride for us to compare things. We could maybe uses frequency or cycles, but that will require a bunch of research to find comparable data to dial in what cars feel like mush, feel just right, or are too harsh. That's not easy data to get.
One thing to keep in mind is that there are many competition cars running softer spring rates with higher roll rates. You want just enough spring rate to suspend the front and give reasonable dive resistance, but control transition with a lot of shock control and let the sway bar control the corner loads.
Originally Posted By crash520
It’s a 73, right now I have 15” rims but I’m going 18’s, prob 45 series, it’s mostly street driven and I have QA1 shocks, I barely noticed any difference in going larger and a lot of guys say the same, go bigger, I also drag race and some circuit track so I’ve had to compromise some
In my experience, larger t-bars in bracket racing will not produce optimal e.t.s, but rather will produce more consistent e.t.s.
RPro,
245’s up front & oversteer: Is this due to the 1.12” bars and my existing stock front sway bar?
Oversteer is too much rear rate, understeer is too much front rate. To balance the above, try a larger front sway bar.
#2437853 - 01/20/18 07:18 AM Re: 1.06" or 1.12" FF Torsion Bars, Street [Re: TC@HP2]
YO7_A66 Offline
Loc: Indiana
Thank you Mitch and HP2! It looks like I need to let this info soak in before I make my choice.
I appreciate all of the replies👍👍. It helps to see what others have already tried.
340 (SL.P. 226/238@.050,270/288 dur,.538"/.528" w/Yella Terra 1.65 rockers, 9.7:1, 63cc Sidewinders (Bowl Ported),RPM intake, QF SS-750 Annular DP, MSD Street Fire Ign., & TTI's. 727/Dynamic 9.5" 3800, TF-2, & 3:91's
#2438903 - 01/22/18 07:46 AM Re: 1.06" or 1.12" FF Torsion Bars, Street [Re: YO7_A66]
BigBlockMopar Offline
Loc: The Netherlands
Don't forget Sway-a-way which also has a nice selection of bars for most Mopar-platforms.
Better prices as well;
https://swayaway.com/product/mopar-b-torsion-bar-set/
BigBlockMopar.com
#2439259 - 01/22/18 08:29 PM Re: 1.06" or 1.12" FF Torsion Bars, Street [Re: BigBlockMopar]
YO7_A66 Offline
Loc: Indiana
The Swayaway sight shows 1.08" bars up
EDIT: The Bergmans and the Swayaways look very similar. I wonder if they are the same manufacturer.
Edited by YO7_A66 (01/22/18 08:32 PM)
#2439340 - 01/22/18 10:44 PM Re: 1.06" or 1.12" FF Torsion Bars, Street [Re: YO7_A66]
RylisPro Offline
Loc: NorCal
I would have no issue getting a 1.14" bar or even a thicker TB from Sway-away, as long as they make quality parts. My 1.12" TB's will bounce up and down when you rock the front end of my car. Every other performance car at every track I run at would never do that due to their modern suspension and extremely high coil spring rates.
/Drive
Instagram: @rylispro
YouTube:RylisPro
www.rylispro.com
925-214-9192
Tremec T56 Magnums & Quick Time bells
Lightened Billet Steel Flywheels
Prefix Performance
Page 2 of 2 < 1 2
25,708 Registered Members
196,876 Topics
Small Chrome Plating System
by jim6346
01/23/19 02:09 PM
1968 Dart conversion from sedan to hardtop
by maximus
01/23/19 01:15 PM
Tire Diameter Selection
by gzig5
01/23/19 12:08 PM
1971 Dodge 500 truckt i wish it was
by TNos
01/23/19 11:56 AM
