Honing oil #2437882
01/20/18 12:16 PM
01/20/18 12:16 PM
Penna
70satelliteguy Offline OP
Penna
I am freshening my motor this winter and putting in new rings. I don't have honing oil. Can I use some other oil?
Thanks Mike
Re: Honing oil [Re: 70satelliteguy] #2437886
01/20/18 12:37 PM
01/20/18 12:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Transmission fluid.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Honing oil [Re: 70satelliteguy] #2437995
01/20/18 04:27 PM
01/20/18 04:27 PM
I've used diesel fuel, kerosene or cleaning solvent with a little oil in it to hone in a garden sprayer up scope
Re: Honing oil [Re: 70satelliteguy] #2438006
01/20/18 04:59 PM
01/20/18 04:59 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Transmission fluid.
Re: Honing oil [Re: 70satelliteguy] #2438053
01/20/18 06:36 PM
01/20/18 06:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Kerosene, cleans better ( what it's supposed to do) and let's the stone cut good, and not lubricate the wall.
Re: Honing oil [Re: 70satelliteguy] #2438245
01/21/18 01:56 AM
01/21/18 01:56 AM
PA
Scully Offline
Scully  Offline
PA
What are you using for a hone, I have 2-5 gallon jugs of lightly used Goodson honing oil for sale in PA but if you're just deglazing a block one time it might not be worth your trouble.
Re: Honing oil [Re: 70satelliteguy] #2438316
01/21/18 11:45 AM
01/21/18 11:45 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
hand honing I think is best with tranny fluid cut 50 % with mineral spirits. Thins the fluid for spraying with a hand sprayer bottle, and washes the cylinder and stones better. In fact I keep a bottle around all the time and use it for all kinds of stuff. Just used it Fri. while machining some aluminum, and I have a bottle of alumi-cut sitting on the shelf.
Re: Honing oil [Re: Scully] #2438446
01/21/18 03:28 PM
01/21/18 03:28 PM
Penna
Penna
I am using a "Flex-Hone". Has a whole bunch of little black balls on it.
Instructions says to not use any solvent!
Used a Mixture of Transmission fluid and WD-40(or as my wife calls it, DW-30!). Worked great. Was just a deglazing hone for new rings so a quick 20 seconds on each cylinder did the trick.
Thanks for the reply's.
Mike
Re: Honing oil [Re: 70satelliteguy] #2438462
01/21/18 04:10 PM
01/21/18 04:10 PM
I use the BRM flexhone & I used what it said on the box. Why does the wife say DW30?
Re: Honing oil [Re: RapidRobert] #2438492
01/21/18 05:27 PM
01/21/18 05:27 PM
Penna
Penna
" Why does the wife say DW30? "
Same reason I call of her shoes,makeup and jewelry by the wrong names I guess!!! LOL
Mike
Re: Honing oil [Re: 70satelliteguy] #2438520
01/21/18 06:15 PM
01/21/18 06:15 PM
You may inform her that WD is for Water Dispersent so it is critical that the letters are in the right order & that the inventor (of it) tried 39 different chemical combinations before being comfortable with/& settling on the 40th try. I use it alot mainly cuz it is handy/thin/sprayable but alot of mechanics dont think very highly of it.
Re: Honing oil [Re: 70satelliteguy] #2438925
01/22/18 11:57 AM
01/22/18 11:57 AM
an8sec70cuda Offline
I've always just used WD-40 when doing a quick "dingleberry" deglaze/hone. Then wipe down w/ ATF.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Honing oil [Re: 70satelliteguy] #2438950
01/22/18 12:56 PM
01/22/18 12:56 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Mike
When a shop hones the bore it is only about 6 passes on the bore so I don't know if any extra will harm things.
Re: Honing oil [Re: pittsburghracer] #2439391
01/23/18 03:24 AM
01/23/18 03:24 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Originally Posted By pittsburghracer
Transmission fluid.
I've always used ATF.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Honing oil [Re: OhioMopar] #2439406
01/23/18 04:10 AM
01/23/18 04:10 AM
I quit using any of the dingleberry hones 30+ years ago when I started using moly coated top rings per the feed back from all the major ring companies shruggy
If your trying to do a quick cheap rebuild on the motor to flip a car and your going to use the cheapest cast iron rebuilder ring sets you can get then your using the proper honing tool needed to do that up
If you want to help make the motor better by straightening the bore taper up and making the cylinders round when honing it then take it to a shop that has a good honing machine or buy a professional hand held hone like Snap On or a adjustable Lisle and use it with a good honing plate and use the same head gasket your going to use on that motor scope up
Re: Honing oil [Re: Cab_Burge] #2439479
01/23/18 12:18 PM
01/23/18 12:18 PM
Penna
Penna
Good points Cab ,but the motor only has 150 passes on it since bored and I am just replacing the rings and bearings since I have it apart from a cam pin breaking off and going thru the motor.
Thanks Mike
Re: Honing oil [Re: 70satelliteguy] #2439564
01/23/18 02:53 PM
01/23/18 02:53 PM
FWIW...my hemi was originally built in 2006. Since then I've re-ringed it twice (moly rings) and used a "dingleberry" hone both times. It will still give me timeslips like it did when it was fresh. Best MPH ever on motor in 2007 was 140.4 mph in good air. The last time I ran the car on motor in good air, it went 140.2 mph after the two previously mentioned freshen ups (8 years later).
Not saying this type of hone is best, it certainly isn't, but it sure aint all that bad either.
CHIP
Re: Honing oil [Re: 70satelliteguy] #2440469
01/25/18 11:37 AM
01/25/18 11:37 AM
crlush Offline
crlush  Offline
I liked mineral spirits beter than trans fluid, to me it seemed to cut faster and seemed like it kept the stones from loading up.
