I would recommend that you use the 10.5" bell/flywheel like the 70-1 cars used. Especially with stock exhaust manifolds.
Thanks for reply. I didn't know 10.5" would be a better choice. I have a couple of bell housings for 11" which is why I was hoping to save money not having to buy a new housing. And yes I am using the stock exhaust manifolds.
Is there a casting number for the 10.5" bell housing?
The 10.5" flywheel....do you know what the teeth count is?
With the 10.5" will I be able to bolt in a high torque starter and function with no issues?
Thx,
Wolf
