Fiberglass parts. #2437440
01/19/18 01:35 PM
01/19/18 01:35 PM
southeast ky
mills.mopar Offline OP
southeast ky
Anyone have any experience with buying fiberglass parts?
I'm looking for a dash, rear bumper and brackets for 68 dart. I understand most parts are not perfect, but also don't want pure junk... If it matters is for a race only car... Let's here your experiences good or bad.
Jeff
If you love it lube it
68 dart
37 dodge coupe
71 challenger
Re: Fiberglass parts. [Re: mills.mopar] #2437487
01/19/18 02:44 PM
01/19/18 02:44 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Glasstek has very nice products.
Re: Fiberglass parts. [Re: mills.mopar] #2437489
01/19/18 02:46 PM
01/19/18 02:46 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
AAR makes nice stuff
Re: Fiberglass parts. [Re: mills.mopar] #2437501
01/19/18 03:12 PM
01/19/18 03:12 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
You'll find people will like and complain about the same placs/parts... I've bought from Unlimited and it was a nice, but other say they only make junk.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Fiberglass parts. [Re: Silver70] #2437535
01/19/18 04:05 PM
01/19/18 04:05 PM
Unlimited use to make junk before the company was bought and relocated to the High desert in SO CA ten + years ago. Bad reputation die hard shruggy
I've bought and use two hoods from them, good stuff now up
Re: Fiberglass parts. [Re: mills.mopar] #2437568
01/19/18 05:43 PM
01/19/18 05:43 PM
VA
VPofGreen Offline
VPofGreen  Offline
VA
Agreed on AAR and Glasstek. Both top shelf products with great customer service.
Re: Fiberglass parts. [Re: mills.mopar] #2437621
01/19/18 07:51 PM
01/19/18 07:51 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Lightweight racing type parts are not going to be of the same quality as the resto/replacement type. Every lightweight racing part on my Challenger has needed work to fit and function as it should. I imagine that a dash and bumper are pretty straight forward either way. I would buy the bumper and make some aluminum brackets to fit it like you want it to look. There was a member here making a nice fiberglass dash for your Dart.
Re: Fiberglass parts. [Re: mills.mopar] #2437714
01/19/18 11:05 PM
01/19/18 11:05 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
B1 is no longer in the dash business.... I have one in my stash of stuff. not sure when it will get installed.
Jeff Lingenfelter makes some nice aluminum brackets for glass bumpers.... in case your fab skills are limited and you like nice stuff (describes me to a "T").
http://lingenfeltersbrackets.com/
I had a VFN hood on the Duster when I got it from my dad with a Harwood 5" cowl grafted to it. Not sure how much work went into it, but it was REALLY nice in the fit and finish department.... buuuuuttt is weighed like 37Lbs. I installed an Unlimited "lightweigh" hood on it last fall. You could literally see daylight through it. Painted it weighs just a bit over 14lb. fit and finish not as nice, but it's "racecar" good enough!
Re: Fiberglass parts. [Re: J_BODY] #2437732
01/19/18 11:41 PM
01/19/18 11:41 PM
Saskatchewan, Canada
barracudabob Offline
VFN Fiberglass have some nice products. I've used their doors and fenders and was happy with them. They did need some work though.
Re: Fiberglass parts. [Re: mills.mopar] #2437899
01/20/18 12:57 PM
01/20/18 12:57 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I have all Unlimited panels on my car. Yes, needed some touch up work, but so did the rest of the car. I like the end result.
[image][/image]
Re: Fiberglass parts. [Re: mills.mopar] #2437992
01/20/18 04:22 PM
01/20/18 04:22 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
VFN on my Dart as well. Nice fit and finish
