71 340 engine detail questions #2437030
01/18/18 07:42 PM
01/18/18 07:42 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
On a 71 340 engine is the PCV valve painted engine color?Also,are the water hose nipples painted or natural?Thanks for any replies.
Re: 71 340 engine detail questions [Re: 5carguy] #2437059
01/18/18 08:30 PM
01/18/18 08:30 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Pcv yes, water nipples no.
Re: 71 340 engine detail questions [Re: ScottSmith_Harms] #2437318
01/19/18 04:17 AM
01/19/18 04:17 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Another question along the lines of detail. My 74 360 has a braided ground from the back of the engine to the firewall (cowl) but my 71 340 does not have the braided ground at the back of the engine, just the negative cable from the battery to the front of the engine with a 10 gauge wire from the negative cable to the side radiator support. Is this correct?
Thanks.
Terry
Re: 71 340 engine detail questions [Re: 71vert340] #2437333
01/19/18 05:46 AM
01/19/18 05:46 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Yep.
Re: 71 340 engine detail questions [Re: 5carguy] #2437379
01/19/18 11:54 AM
01/19/18 11:54 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Another couple of quick questions,is the vacuum nipple for the power brake painted and also how about the temp sender in front of the manifold?
Re: 71 340 engine detail questions [Re: 5carguy] #2437394
01/19/18 12:21 PM
01/19/18 12:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No on both
