Re: Oil Pump Instal
[Re: 71birdJ68]
#2437184
01/18/18 11:52 PM
01/18/18 11:52 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
Putting a new oil pump on my BB, do you all prep yours any any way? Why?
Re: Oil Pump Instal
[Re: 71birdJ68]
#2437290
01/19/18 02:24 AM
01/19/18 02:24 AM
RapidRobert
Clean it good. quick check of the (3) (IIRC) clearances with a feeler gauge, lube it & have the intergear installed before torqueing the pump mounting bolts to effect a dead on hex alignment.
Re: Oil Pump Instal
[Re: Brewzer67]
#2437864
01/20/18 11:18 AM
01/20/18 11:18 AM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
I take mine completely apart (including removing the O-rings)and check to make sure there is no loose metal chips, etc from machining. Then I port them like a cylinder head and remove any sharp edges the oil may have to pass over. I also check the pressure relief valve for proper fit and any machining irregularities to make sure it won't possibly hang up once assembled. I also check all mating surfaces for flatness and proper clearance for the gerotor pieces. Once I am sure all is good,I clean it up with brake clean. Then I lube up the inside with some Vaseline and put it all back together lubing all O-rings. Before I mount it to the block, I coat both sides of the paper gasket in a light coat of gasket shellac and then assemble right away. A little putzy, but it's the little things that will get you. 100% NEVER EVER just bolt an oil pump onto an engine without complete blue print of the unit. Remember that this is probably the single most important component of your engine. I use a small Dremel to de-burr and smooth out the passages then wash and rinse with hot soapy water. Then Vaseline or assembly lube everything. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Oil Pump Instal
[Re: 71birdJ68]
#2437929
01/20/18 01:46 PM
01/20/18 01:46 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
I took the cover off my Melling 63 HV before installing
Looked clean
Everything moved freely A little oil Put the cover back on
Superformance Gasket - Installed o ring on pump A little black rtv silicone on gasket
Primed the engine before breaking in the cam 10w30w Comp Cams Break In Oil
75 psi at RPM's
25 / 35 psi at Idle
How many engine or machine shops on any make rebuilt engines would actually take apart a brand new oil pump and blueprint it before installing ?
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: Oil Pump Instal
[Re: bee1971]
#2437989
01/20/18 04:18 PM
01/20/18 04:18 PM
Posts: 43,095 Bend,OR USA
Cab_Burge
I won't use vasoline or grease on the pump gear or rotor The motor runs on oil, use that to thoroughly coat the insides of the pump, rotor, gears and the gear shaft up in the pump body and on the O ring and pump body shaft that slides into the block No RTV on the gasket either, gasket cinch or gasket adhesive lightly on the gasket to hold it in place
Re: Oil Pump Instal
[Re: stumpy]
#2438384
01/21/18 01:40 PM
01/21/18 01:40 PM
RapidRobert
permatex 99MA "high tack" the thin red spray in the purple can works well for these (& some other) gaskets. goes on real thin/super tacky/holds gaskets in place (its best quality).
Re: Oil Pump Instal
[Re: RapidRobert]
#2438476
01/21/18 04:40 PM
01/21/18 04:40 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I have never needed to glue any of my gaskets. Flat, & clean, does the trick. Replaced a few oil pumps and just bolted 'em on right out the box. I fill oil pumps with oil. Never an issue. Results may very. Do what ever makes you feel safe.
I have mechanical Aptitude. I can screw up anything.
Re: Oil Pump Instal
[Re: bboogieart]
#2438522
01/21/18 06:21 PM
01/21/18 06:21 PM
RapidRobert
there are a few gaskets (timing cover especially) & intake side gaskets that need help staying put.
Re: Oil Pump Instal
[Re: 71birdJ68]
#2439270
01/22/18 11:50 PM
01/22/18 11:50 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I take every one apart. That was instilled in me in tech school in the 80s. You don't have to blueprint - I never do, But you need to clean them out, check things, make sure the relief valve functions, and adding a little grease on the rotors will pull the oil up a lot faster when you preoil.
Re: Oil Pump Instal
[Re: moper]
#2439283
01/23/18 12:20 AM
01/23/18 12:20 AM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
I take every one apart. That was instilled in me in tech school in the 80s. You don't have to blueprint - I never do, But you need to clean them out, check things, make sure the relief valve functions, and adding a little grease on the rotors will pull the oil up a lot faster when you preoil. I agree that blueprinting is overrated since I witnessed a scrap oil pump having zero effect on pressure once before. It was after the 1st fire up on a 440. With 10w30 it had too much oil pressure. Probably due to tight clearances. Nobody was willing to change the clearances so we removed the brand new pump, easy job on a big block. Installed the high mileage pump that was in the scrap bin from before the rebuild. I was skeptic, not due to clearances but the obvious signs of scoring on the rotor. Anyways after the pump swap there was ZERO change in pressure. This was according to a large sweep Autometer with 1 psi graduations.
