Best head porting shops #2435877
01/16/18 08:37 PM
01/16/18 08:37 PM
usa,pa
jkwedge540 Offline OP
usa,pa
I am look for someone to soften the chambers and go over my B/1 heads. Who do you guys recommend. I was looking at Al Neil.
Re: Best head porting shops [Re: jkwedge540] #2435916
01/16/18 09:29 PM
01/16/18 09:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Call Dwayne Porter.
Re: Best head porting shops [Re: jkwedge540] #2435943
01/16/18 10:11 PM
01/16/18 10:11 PM
A727Tflite Online content
A727Tflite  Online Content
Dwayne Welder in Michigan.
Worked at many of the best shops in Michigan, raced with some of the best Super Stock guys in the 70's and 80's,
Is 2nd to none for hand porting.
Re: Best head porting shops [Re: jkwedge540] #2436070
01/17/18 01:01 AM
01/17/18 01:01 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Porter hands down!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Best head porting shops [Re: hemi-itis] #2436108
01/17/18 01:52 AM
01/17/18 01:52 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By hemi-itis
Porter hands down!
I agree as Dwayne Porter did awesome work on my heads and cam. And every car I see with some of his work done to it runs great. Ron
Re: Best head porting shops [Re: jkwedge540] #2436121
01/17/18 02:38 AM
01/17/18 02:38 AM
New York, USA
Chargerfan68 Offline
New York, USA
Dwayne Porter does exceptional work. High quality and attention to detail seldom seen these days.
Re: Best head porting shops [Re: jkwedge540] #2436148
01/17/18 04:02 AM
01/17/18 04:02 AM
Cab_Burge Online work
Cab_Burge  Online Work
What does "soften the chambers mean"?
Re: Best head porting shops [Re: jkwedge540] #2436237
01/17/18 12:15 PM
01/17/18 12:15 PM
an8sec70cuda Offline
I'm a huge fan of Dwayne Porter's, but I'm not sure he does any chamber softening.
Look at Buck's Racing engines in NC, Slawko, or Hemphill up there by you in PA.
Cab...it's a modification (enlarging) to the combustion chamber making it more nitrous friendly.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best head porting shops [Re: an8sec70cuda] #2436257
01/17/18 12:38 PM
01/17/18 12:38 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Chip,
I think your correct on this one. Dwayne doesnt do a ton of nitrous stuff, nor a ton of B1's, doesnt mean he woudnt, I am sure he will chime in here and advise.
If he doesnt or cant, I like 2 on your list for that.
1) Slawko
2) Bucks
Not sure if Brandywine is still around,Speier,Carl Fults etc, Do a little research with the nitrous guys and you'll see, but I think Buck and Slawko are two good choices. Monte Smith used to like Bucks work.
RIP Monte Smith
Re: Best head porting shops [Re: Cab_Burge] #2436263
01/17/18 12:49 PM
01/17/18 12:49 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
It's a very shallow, slightly angled concave cut on the quench pad area of the chamber. It makes the engine less timing sensitive and opens up the tuning window on heavy nitrous or boosted applications.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: Best head porting shops [Re: jkwedge540] #2436296
01/17/18 01:31 PM
01/17/18 01:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Chip and Todd are correct.
I appreciate the confidence, but that type of work is a little out of my wheelhouse.
Re: Best head porting shops [Re: Runnoft] #2436364
01/17/18 03:57 PM
01/17/18 03:57 PM
Thanks up
I leaned something new today bow
Re: Best head porting shops [Re: jkwedge540] #2436372
01/17/18 04:05 PM
01/17/18 04:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Slawko....
