#2426566 - 12/31/17 03:26 PM Wanted - Big Block Engine - 1st Quarter
moparts Offline
#2426774 - 12/31/17 07:41 PM Re: Wanted - Big Block Engine - 1st Quarter [Re: moparts]
440mopar Offline
Loc: USA
Big block parts wanted:
A nice big block cast crank two groove pulley for my 1972 400. I would like a pulley that is specifically for a cast crank so that it has the proper bolt hole spacing.
A 383-400 high rise throttle bracket kit and return spring bracket.
I am also looking for the following 1967 440 engine parts:
Carter AFB carb. #4327S
Correct carb to intake bolts
Correct Carter AFB carb choke with choke housing bolts
Automatic trans. distributor #2642748
Fan clutch #2806070
1967 dated alternator with single groove pulley
Two groove crank pulley
fourfortymopar at yahoo.com
Edited by 440mopar (01/17/18 10:28 AM)
#2429756 - 01/05/18 11:12 PM Wanted - 440 Crank Drilled for 4-Speed [Re: moparts]
PurpleBeeper Offline
Loc: Chicago
I'm looking for a forged 440 crank that has the pilot bushing hole drilled. I'm in the St.Louis area and can drive to meet you. What do you have?
FOUND ONE --> Thanks Moparts
Edited by PurpleBeeper (01/14/18 03:41 PM)
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
#2435034 - 01/15/18 12:41 PM Re: Wanted - 440 Crank Drilled for 4-Speed [Re: moparts]
Loc: Chicago
I'm trying to find an inexpensive aluminum 440 six pack intake. I don't need a "dated A-12" and am just looking for something cheaper than new/aftermarket.
Found one..thanks Moparts
Edited by PurpleBeeper (02/11/18 06:51 PM)
#2435191 - 01/15/18 05:36 PM Re: Wanted - Carb for 70 RR [Re: moparts]
Sledge_57 Offline
Loc: Dearborn Hts, MI
Posting for a friend. Looking for a Holley R4736-1A (part number 3512 964) for a 1970 Roadrunner.
Doug
1967 "Pedal Car" Dead 470 (really a Pedal Car now), TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
#2435930 - 01/16/18 06:48 PM Re: Wanted - 69 Date Coded Starter Barrel [Re: Sledge_57]
Falbz Offline
Loc: California
Looking for a black 69 date coded starter barrel Part #2875560 with a date stamp 419 - 479. Please lmk what you have and how much you are asking.
Plz pm or email: Falbz@aol.com
Edited by Falbz (01/16/18 06:48 PM)
#2436255 - 01/17/18 09:35 AM Re: Wanted - 69 Date Coded Starter Barrel [Re: moparts]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
Got em, thanks Shatar!!!
Edited by an8sec70cuda (02/01/18 11:07 AM)
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan SXT...baby hauler
#2436375 - 01/17/18 01:08 PM BB 383-440 rocker shaft spacer rings & hold down hardware [Re: an8sec70cuda]
moparjohn Offline
Loc: N.W. INDIANA
I am trying to complete some factory BB 383-440 rocker arm assemblies. I have a few that are missing the spacer rings between the rockers. I am also missing some hold down hardware. I have attached a picture of the parts I'm looking for. This is a low budget project so I don't want any one pulling their complete sets apart as that will not move us forward overall. Just looking for oddball parts and pieces from blown engines or engines where hardware has been upgraded. I will pay 50 cents a piece for the spacer rings and the bolts and a dollar a piece for the hold down brackets. I will be at the Chicagoland Mopar Connection Swap on February 18th to save shipping on these small items. You can contact me at: moparjohn@frontier.com
Thanks!
#2436905 - 01/18/18 01:12 PM Wanted - Big Block 6qt Pan + 3/8" Oil Pickup Tube [Re: moparts]
Loc: Chicago
I'm looking for a big block 6qt. oil pan + 3/8" pickup tube long enough (& fits) the pan. This is basically the "hemi/six-pack" size pan with the smaller diameter 440 pickup. It can be a stock or aftermarket set.
This is for a 70-body with a skid plate on the engine cross-member.
Thanks!
THINK I'M GOING WITH MANCINI ON THIS ONE... thanks Moparts
Edited by PurpleBeeper (02/11/18 06:52 PM)
#2447040 - 02/05/18 05:04 PM Re: Wanted - Big Block Engine - 1st Quarter [Re: moparts]
dart4forte Online   boogie
Loc: Mesa, Arizona
Looking for a bigblock A body distributor, part number 2875359, need it to be in good condition enough to where it can be restored. This dizzy should be a cast iron housing.
#2447547 - 02/06/18 04:02 PM Re: Wanted - Big Block Engine - 1st Quarter [Re: moparts]
GLR Offline
Loc: Northern Pa
Wanted/looking for a good used set of the earlier Mopar Stage VI heads, the one's that when you installed them on a B engine (383/400 block) you used an RB (440) intake...or if you had the heads on a 440/RB engine you had to use the spacer plates and the RB intake. I know I can buy better heads than these old Stage VI heads... but it is for a specific application.
Thank you!
#2448502 - 02/08/18 11:12 AM Re: Wanted - Big Block Engine - 1st Quarter [Re: moparts]
DBCooper Offline
Loc: South Louisiana
WANTED - 509 lift Purple shaft hydraulic cam and lifters if available for a B/RB engine New or used will be fine
Thanks in advance !!
#2449160 - 02/09/18 02:41 PM Re: Wanted - Big Block Engine - 1st Quarter [Re: DBCooper]
cudacar340 Offline
Loc: Grosse Isle, Mi
looking for a 1 groove crank pulley for 383 or 440, not crusty or pitted bad
thanks
Edited by cudacar340 (02/09/18 02:43 PM)
#2449287 - 02/09/18 07:28 PM Re: Wanted - Big Block Engine - 1st Quarter [Re: moparts]
CHADCLINE22 Offline
Loc: PARIS,IL 61944
Needing a 400 dipstick and tube for a c body. Must be willing to ship. Paypal preferred. Thanks!
#2449993 - 02/11/18 09:05 AM Re: Wanted - Big Block Engine - 1st Quarter [Re: moparts]
BLACKHEMIRR Offline
I'm looking for a set of new or good used 426 MW pistons, L2184 or L2208. I need .005, .020 or .030 over. Please PM me here if you can help.
Thanks for the ad.
#2451680 - 02/14/18 12:08 PM Re: Wanted - Big Block Engine - 1st Quarter [Re: moparts]
Transman Offline
Loc: Michigan
Need one adjustable rocker arm for B/RB - see image.
Either style - with interference fit adjuster or locknut style.
Please PM with cost.
#2452261 - 02/15/18 03:45 PM Re: Wanted - Big Block Engine - 1st Quarter [Re: moparts]
Transman Offline
Loc: Michigan
Wanted - set of standard wedge aluminum rocker stands.
Don't need the maxwedge stands.
Just plain old standard stands.
PM me if you have a set you are interested in selling, include price.
25,144 Registered Members
186,688 Topics
727 auto trans ID help
by 5carguy
02/20/18 04:53 PM
TTI 2.5" X pipe exhaust/Gear Vendors - E body
by BcudaChris
02/20/18 04:07 PM
New to the C-Body scene
by jim6346
02/20/18 04:03 PM
1973 Plymouth Roadrunner H Code Mopar
by FM3_1970
02/20/18 02:56 PM
