Re: Duplicolor Ceramic Engine Paint Chrysler Torquoise Any used
[Re: Centerline]
#2434513
01/14/18 05:26 PM
01/14/18 05:26 PM
Posts: 15,828 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I know it's not what you asked, but I used the Mopar brand, and it covers REALLY well, and I've used it in the past and it has held up well too. Available jegs, summit, etc. Yes, I still need to do water pump.
Facts are stubborn things.
[Re: 65pacecar]
#2434819
01/15/18 02:52 AM
01/15/18 02:52 AM
Posts: 5,161 CT
GTX MATT
CT
No, none are correct, they might as well be blue. Closest I have found is Seymour Detroit Diesel Alpine Green. I've been wanting to try the Dupli-Color Detroit Diesel too, it looks like its also pretty close.
[Re: 65pacecar]
#2434822
01/15/18 02:57 AM
01/15/18 02:57 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I've used por 15s engine paint and the colors have been right on with the mopar spray cans.... but it's shinier and far more durable.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 6bblgt]
#2434959
01/15/18 01:30 PM
01/15/18 01:30 PM
Posts: 5,161 CT
GTX MATT
CT
6BBLLGT - That valve cover looks very blue to me. Every Turquoise big block I've ever had looked much more green (like the Alpine green) than any of these blue colors sold as "Chrysler Turquoise" or that valve cover. The paints sold as "Chrysler Turquoise" would probably be a close match on that valve cover. I honestly could not differentiate between that valve cover and 72 and up Corporate blue. But you are right, the aging does effect it.
One other thing - Mancini sells paint now that they claim is a correct match.
[Re: 65pacecar]
#2434984
01/15/18 02:19 PM
01/15/18 02:19 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
No experience with the turquoise; but I like the Hemi orange. Add reducer and their hardener, spray with a gun. The hardener increases gloss according to their literature. With the hardener, it's as durable as BC/CC, spray it with brake cleaner, lawyer thinner, etc and it wipes off as clean and shiny as the day it was sprayed.
Just don't spray it too thick, and make sure all oil and grease is out of the pores of the casting. I have a problem of not wanting to be wasteful, and spraying everything I mixed up. One engine got too thick and when replacing the water pump, the paint chipped and lifted
**Photobucket sucks**
[Re: Yellow Fever]
#2435440
01/16/18 03:21 AM
01/16/18 03:21 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Bill Hirsch on my old Satellite. Hirsh's green looks a lot closer to the orig color of my 64 Belvedere's 383. I tried Duplicolor Chrysler green & its too blue. (you can see the thermostat cover I sprayed with it doesn't match.) Tried VHT early Chrysler blue & no close match there. Think I'll give Frank Badalson a call as his paints seem to be good matches. Could have my valve cover scanned & paint matched locally, but a can of mixed spray paint is about $70.
[Re: mopower440]
#2649708
04/27/19 10:50 PM
04/27/19 10:50 PM
Posts: 20,749 A collage of whims
topside
A collage of whims
About 20 years ago, Krylon 91904 Teal Blue was a pretty good rattle-can match, but it's no longer available. Looking around on the web, Krylon now has a 5568 Satin Jade that may be close in hue, but it's satin. Jeg's shows the Mopar P4120752AB available, and in a sprayout photo it looked pretty accurate, though darker - ??? Also saw VHT's SP126, also looks fairly accurate but haven't tried it. I bought a can of Classic Industries' K89162 but haven't tried it yet. Hirsch's color seems off to me, which surprises me as I've used their Chrysler Red and it was accurate and great out of a gun. The photo Triggerfish posted looks most accurate to what I recall mine being.
