#2434175 - 01/13/18 08:50 PM Need help id'ing an old table saw
magnum440d100 Offline
Loc: woodcrest, CA
I did some work for an older gentleman, his wife passed and he ended up needing a quadruple bypass (at 86) and moved to Indiana to be near family for rehab.
I wound up with all of his wood working equipment (table saw, router, chop saw, jointer, etc).
Today I used the saw for the first time since I got it last year, and it is so smooth and great. It is belt powered and very powerful.
I was wondering if you guys can help narrow down the year (decade?) of manufacture. I'd like to acquire more equipment from the same era.
Thanks in advance!
#2434184 - 01/13/18 09:08 PM Re: Need help id'ing an old table saw [Re: magnum440d100]
Ashsdad Offline
Loc: Washington, MI
check out OWWM.org. Its a website for old machines like that. The old Craftsman stuff is fairly popular and they have an online library of factory manuals for older equipment too.
70 Challenger ragtop, only a 318, but its always been mine!!!
#2434186 - 01/13/18 09:14 PM Re: Need help id'ing an old table saw [Re: magnum440d100]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
That appears to be a Craftsman plate. Get a photo of the serial number on it & post it.
#2434207 - 01/13/18 09:57 PM Re: Need help id'ing an old table saw [Re: magnum440d100]
srt Offline
Loc: Fire and Fury
Over the years I've searched the brand/item/model number/manual and found the manual then download it if available (usually pdf) somewhere in the first couple pages or the back cover will be a date.
In your case search craftsman table saw model 113.xxxxx manual in the search results you can usually find the manual,listed, if not look at images and locate the equipment you're identifying.
From what I know that style is late 50's and into the 60's. I had a all cast iron 8" version I negligently traded for a newer 10". I later found it was a war model...
#2434208 - 01/13/18 09:58 PM Re: Need help id'ing an old table saw [Re: magnum440d100]
Orange_Crush Online   content
Belieber!
Loc: Charlotte, NC
That's a '50s vintage Craftsman 113 table saw (there should be a tag on it somewhere with that model number).
It probably has a 1 or 1.5 horsepower motor. They last forever but they can be a little weak cutting thicker hardwoods unless you have a really good blade.
Here is a thread on Garage Journal
https://www.garagejournal.com/forum/showthread.php?t=225278
There are better saws out there, but thw old 113 is quite a decent saw, especially if you add a good fence (which is a weak link on the 113).
There are a couple of good resto threads out there for these as well a couple of good youtube videos.
I have a later one (late 70s) they made them for about 30 years, I think. I added a 2HP 240v. motor to mine. Its awesome.
Edited by Orange_Crush (01/13/18 09:59 PM)
1970 Dodge Charger R/T Hemi Orange U-code 4-speed
1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
#2434285 - 01/14/18 02:14 AM Re: Need help id'ing an old table saw [Re: magnum440d100]
Loc: woodcrest, CA
Sorry for the late response. I was away from the house.
It does appear it is a model 113 up
#2434286 - 01/14/18 02:17 AM Re: Need help id'ing an old table saw [Re: magnum440d100]
Loc: woodcrest, CA
Sorry about the bad pics. Working off my phone and it doesn't let me preview the pics before I select them. Serial number is 113.27580
#2434287 - 01/14/18 02:19 AM Re: Need help id'ing an old table saw [Re: magnum440d100]
Loc: woodcrest, CA
This is the motor on it
#2434288 - 01/14/18 02:22 AM Re: Need help id'ing an old table saw [Re: magnum440d100]
Loc: woodcrest, CA
The motor appears to be a craftsman 3/4hp. I wonder if it's original?
#2434314 - 01/14/18 07:56 AM Re: Need help id'ing an old table saw [Re: magnum440d100]
Belieber!
Loc: Charlotte, NC
That's the original motor and it should be fine for about anything you'll use it for...unless you have projects that require cutting thicker oak and maple. FYI, those motors are rebuildable by any motor shop.
A common upgrade people do to these saws is adding one of these
https://m.harborfreight.com/engines-generators/electric-motors/2-hp-compressor-duty-motor-67842.html
#2434393 - 01/14/18 10:39 AM Re: Need help id'ing an old table saw [Re: magnum440d100]
srt Offline
Loc: Fire and Fury
Do you have the balance of the number where you can search it?
#2434409 - 01/14/18 11:08 AM Re: Need help id'ing an old table saw [Re: magnum440d100]
markz528 Offline
Loc: Milford, OH
BTW - that motor has a flat capacitor in the base if my memory serves me correctly.
67 Coronet 500 (street car) 13.300 @ 101.75 mph
#2434432 - 01/14/18 12:00 PM Re: Need help id'ing an old table saw [Re: srt]
Loc: woodcrest, CA
113.27580
#2434436 - 01/14/18 12:04 PM Re: Need help id'ing an old table saw [Re: Orange_Crush]
Loc: woodcrest, CA
Thanks for the tips!
Yeah, the hardest wood this one will probably see is pine. I'm thinking of redoing the wood floor on my 65 Chevy in pine. Maybe oak if I can get it at a good price. But it'll be less that 1" thick.
But mostly this saw will be cutting wood to build shelves and cabinets so it'll see mostly Douglass fir and pressboard haha
25,538 Registered Members
194,157 Topics
1952 Plymouth 2-way @ Once car S E SoDak --$7995
by bigdad
13 minutes 51 seconds ago
Window Mechanism Grease
by dart4forte
Today at 12:55 AM
W2 heads- How much lift is lost at the valve?
by viperblue72
Today at 12:53 AM
HOW MUCH are you going to throw at the LOTTO ....
by Doc Fiberglass
Yesterday at 11:54 PM
