Page 4 of 5 < 1 2 3 4 5 >
#2431751 - 01/09/18 04:07 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
brownout Offline
Loc: ca
Southwest Speed floor mount dual master cylinder setup with pedal in good used condition. One Southwest Speed master cylinder and one Wilwood master cylinder. Check part # 301-2582
$100 shipped
call or text Cody at (916) 494-8888
#2431780 - 01/09/18 05:10 PM Re: For Sale - Race Parts - 1st Quarter [Re: brownout]
Jeremiah Offline
Loc: Rogue River, OR
1425CFM Gen3 Holley Dominator - Like New -
Please see this link for details on Holley's site:
Holley 80911HB Dominator
I am also including a phenolic spacer with h/w,an AED throttle cable bracket/return spring combo (anodized red), AN -8 fuel lines and an aluminum carb hat. Please PM for pictures of everything and make sure to include your email address or phone number along with a shipping zip.
Asking $1500 plus shipping. Carb alone is $1400 new!
Thanks moparts for the free ad.
#2431852 - 01/09/18 07:02 PM Indy 622" [Re: moparts]
AlexBosak Offline
Loc: Chicago IL
Unassembled and fresh from machine shop(Opel Engineering) 622-13 heads ported with new springs & valve job, Jesel rockers, new Indy maxx block, new Callies crank, new GRP rods, like new Ross pistons, new rings & bearings, Comp lifters, Trend push rods, Indy/Cam Motion custom grind cam, Hogans sheet metal intake, Pro System SV1 carbs. Just add your belt drive and oiling system for a complete motor. This motor ran 7.40 in a 2250lb car. Running Hemi's now and was going to keep this for index racing but plans changed.15k firm
alex@atrendz.com
Edited by AlexBosak (01/09/18 07:05 PM)
#2431938 - 01/09/18 08:46 PM Re: Indy 622" [Re: AlexBosak]
Azzkikrcuda Offline
Loc: North Dakota
Used Smith Brothers 5/16 diameter .083 wall pushrods, ball and ball ends 9.390 length. Pushrods look new, was setup for 440 solid cam and Comp Pro Magnum rockers. Were $170 new, $100+shipped
Clevite V-series bearings MS-1795V Std. size, 440 small thrust flange. Mocked up but not ran. $50 shipped
PM me here if interested.
The only Carbs I care about are under the hood!
#2431941 - 01/09/18 08:51 PM Ported Indy RB Dominator Intake W/ NOS Fogger, Jets $1000 [Re: AlexBosak]
Jeremiah Offline
For sale, one ported RB (tall deck aka 440) Indy intake. It has been ported and the plenum dividers have been extended. There is some welding around the ports where they meet the flange to add material when the ports were opened up.
This intake has been plumbed with an NOS fogger which includes two sets of solenoids (2 fuel, 2 n20), stainless lines, fogger nozzles and the hose and distribution blocks to tie both sides of the system together. All solenoids have Weather Pack connectors installed. This is an older setup but it is clean and well cared for.
1000 OBO with jets and instructions for the NOS kit.
PM me with you email address and zip code for pictures and shipping costs.
Thanks for the ad Moparts!
#2432622 - 01/10/18 11:19 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
pittsburghracer Offline
Slowride
Loc: PA.
JW powerglide to big block Mopar bellhousing
$300
Freeport, PA
I bought this a couple of years ago and only used it to mock up the engine and transmission in my Duster So I could have headers made. This is used to mate up a powerglide to your big block Mopar. New cost is 472.00 from Summit. Buy this one for 300.00 plus shipping from Freeport, Pa. 16229 PM or jacadamore@gmail.com
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
6.143@110.89 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
6.001@113.27mph
9.44@138.23
#2432656 - 01/11/18 12:28 AM Re: For Sale - Race Parts - 1st Quarter [Re: pittsburghracer]
WHITEDART Online   laugh2
Loc: bean town
Good used 3 vane Moroso vacuum pump with fittings and mount that will bolt to a small block water pump.. this pump pulled 14in on my 408.. over $600 invested... yours for $350 plus the ride.. PM me here... Sold thanks Moparts
Edited by WHITEDART (01/15/18 08:15 PM)
In the 8s N/A.with Brett miller W8
5.42 1/8
#2433023 - 01/11/18 06:08 PM BB Mopar cams for sale [Re: Rocket]
ou812 Offline
Loc: SoCal
Used BBM Comp solid roller cam 23-707-9 $230.00 shipped.
New BBM Comp custom hyd. FT cam: 241@ .050, .546 lift with a 112LCA $150.00 shipped.
New BBM Comp custom hyd. FT cam: 236-246@ .050, .519-.511 lift with a 114LCA $150.00 shipped.
New BBM Comp custom solid FT cam: 247-255@ .050, .549-.571 lift with a 108LCA $175.00 shipped.
Brian
mxnaked@yahoo.com
Brian Hafliger
#2433642 - 01/12/18 07:48 PM Re: BB Mopar cams for sale [Re: moparts]
DavidDean Offline
Loc: Lubbock,TX
A engine Herbert roller lifters
$150 + shipping
PM me for pics or more
#2433680 - 01/12/18 09:12 PM Re: BB Mopar cams for sale [Re: moparts]
DavidDean Offline
Loc: Lubbock,TX
M/T Race tubes to fit 14 x 32 tire #9558 $100.00 pair + shipping PM me for more info & pics
#2434016 - 01/13/18 03:39 PM Re: BB Mopar cams for sale [Re: DavidDean]
joez Offline
Loc: PA
BB mopar 528” low deck rotating assy. 4.505” bore, 4.15” stroke MP crank with B mains and mopar rod journals p5249337. 6.500 Grp rods with 1.031 pin 35 runs. 1 set used diamond pistons 1.360 pin height, 12 new diamond pistons, .043/.043/3/16, coated skirts, vert gas ports. Two sets used venolia rods with hemi pin and 12 used venolia pistons all fit b1mc or b1 heads. Joe – nitrojoez@yahoo.com – 570-436-5544 $1,500 obo plus freight. Located in North east PA
#2434019 - 01/13/18 03:42 PM Re: BB Mopar cams for sale [Re: joez]
joez Offline
Loc: PA
15x10 weld pro stars. 4.5" bolt pattern. 3.5" back spacing. Drilled for screws.
Joe – nitrojoez@yahoo.com – 570-436-5544 $200 obo plus freight. Located in North east pa.
#2434020 - 01/13/18 03:43 PM Re: BB Mopar cams for sale [Re: joez]
joez Offline
Loc: PA
B1 MC valves stealth titanium 2.400 intake and ss 1.780 exhaust 7 of each
#2434021 - 01/13/18 03:44 PM Re: BB Mopar cams for sale [Re: joez]
joez Offline
Loc: PA
Straightline Performance used roller cam. 3 bolt for big block.
Intake: lobe lift 0.481, ratio 1.7, valve lift 0.818, adv dur 313, dur @050 280, lobe cl 109. Exhaust: lobe lift 0.475, ratio 1.7, valve lift 0.808, adv dur 328, dur @050 294, lobe cl 117, LSA 113.
Joe – nitrojoez@yahoo.com – 570-436-5544 $100 obo plus freight
Edited by joez (01/13/18 04:04 PM)
#2434042 - 01/13/18 04:41 PM Turbo Action Converters [Re: moparts]
WadeMetzinger Offline
Loc: Tulsa, Ok
[IMG]https://photos.app.goo.gl/XzEt5km1VyDZa20p1[/URL]
Turbo Action 9" converter - 5,200 stall
In good working condition, just have several on the shelf. Only has 50 passes on it since it was sent to PTC to be freshened.
Stall number above from an NHRA Stocker 1969 Road Runner in I/SA class, 3,750lbs with 383 running 11.50s.
$400 shipped (call or text me 918-809-0987)
Edited by WadeMetzinger (01/19/18 02:28 PM)
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.70@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
#2434090 - 01/13/18 05:49 PM Mopar Performance 0.620” lift Small Block Solid Lifter Cam [Re: WadeMetzinger]
Rocket Offline
Loc: CT
I have a new Mopar Performance 0.620" lift flat tappet camshaft part # P4349266. It shows some very light pitting on two or three of the lobes around peak lift only which might buff out with emery paper. See the last picture for the light pitting. Bearing journals and the rest of the lobe areas are fine and smooth. Pictures show some dark spots which is discoloring from the original coating on the cam. Should be fine to run.
$110 shipped in the lower 48 states.
Contact procketrichard@hotmail.com for more information and pictures.
Edited by Rocket (01/14/18 11:59 AM)
#2434093 - 01/13/18 05:51 PM Cam Dynamics Solid Flat Tappet Camshaft for Small Block [Re: Rocket]
Rocket Offline
Loc: CT
For sale is a small block Cam Dynamics mechanical flat tappet camshaft from my 360 ci bracket motor. The specs are 0.585 lift with 310 degrees advertised duration and 275 degrees duration at 0.050 lift on both Intake and exhaust. This was used for 50 runs and ran a best of 10.48 in my W2 headed 360 ci Dart. The cam comes with the matching solid lifters matched to each cam lobe. Always run with Kendall 20W50 racing oil. Cam and lifters are in good shape. I have the cam card available for the full specifications.
Price is $150 shipped to lower 48 states.
#2434122 - 01/13/18 06:52 PM Re: Hurst Auto-Stick shifter, reverse valve body, 727/904 [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
SOLD!
I have for sale a complete Hurst Auto-Stick shifter setup that came from a 68 Dart with a reverse valve body 727 trans, P/N 3160014. This shifter and parts will also fit the 904 trans application. This setup includes the shifter mechanism, 5’ cable, neutral safety switch (comes with the shifter kit but isn’t needed and never installed for the 904/727), the plastic cover, P/N 1300055, and all the brackets, levers, nuts and bolts to do the installation. The original ball is included since a “T” handle with line lock button is attached to the shifter lever. Also included are the installation instructions for the shifter, the neutral safety switch and the cover.
https://www.summitracing.com/parts/huu-3160014
https://www.summitracing.com/parts/huu-1300055
I would like to get $150 plus shipping for everything.
Edison, NJ
rider1454at aol.com
Edited by PHYSIXX (Yesterday at 07:25 PM)
#2434297 - 01/14/18 04:38 AM B1 originals [Re: PHYSIXX]
Joes66dart Offline
Loc: Middletown, Ohio
Sold sold sold. Ihave a set of b1 originals ported by koffels. I do not have flow sheets. The have k motion springs, titanium retainers. Comes with two sets of 1.7 rockers, B1 valve covers and b1 4500 intake. One exhaust valve needs replaced. Othe4 than that they are ready to go. Asking $3500 plus shipping. Heads located in Trenton ohio 45067. Easy way to contact is text @ 513-465-0699 or email me at 3joespettus@gmail.com. Sold sold sold
Joe
Edited by Joes66dart (01/21/18 08:57 PM)
#2434433 - 01/14/18 12:02 PM Small Block Hydraulic Tappet Camshaft - NHRA Stock Class [Re: Joes66dart]
Rocket Offline
Loc: CT
For sale is a used small block Cam Dynamics hydraulic flat tappet camshaft from an NHRA Stock class drag racing car. The Cam Dynamics part number is 10944 and the grind number is 206-2A. The specs are 0.455 lift intake and exhaust with 303 degrees advertised duration and 265 degrees duration at 0.050 lift on both Intake and exhaust. This was used for 1 season and has been wrapped in an oil soaked rag since. It is in very nice used shape. I have the cam card available for degreeing in the camshaft.
Price is $115 shipped to lower 48 states.
25,084 Registered Members
185,778 Topics
Cuda Challenger Overhead Console Bracket?
by sixpacksteve
01/23/18 04:28 PM
New Tach not working correctly - assistance needed
by ACME_Garage
01/23/18 02:53 PM
Broken pushrod piece ,where does it end up?
by Joesixpack
01/23/18 02:52 PM
5.7 hemi to viper t56 w/ quicktime rm8077, twin disc clutch?
by Silver70
01/23/18 02:44 PM
