Any machine shops in the DFW area that know Gen III HEMI? #2433060
01/11/18 09:58 PM
01/11/18 09:58 PM
D/FW
gts95 Offline OP
gts95  Offline OP
D/FW
I have a 2013 5.7 out of a 21k mile Charger which has a snapped rod. This is the way I purchased the car....I believe it was due to hydrolock. The motor is already out of the car.
I now have to decide whether to rebuild existing (block "appears" unscathed), go with a stroker kit to get all the forged goodies, or maybe pickup a 6.4 out of a wrecked donor (I have access to salvage auctions).
My biggest fear in building the engine is going to a shop that doesn't know their way around one, and getting something that will give me problems down the line. Cost is also a factor. The short-block and long-block options from the well-known players seem PRICEY!! Then add freight charges on top of that. I'd like to find somebody local and obviously live in a big Metroplex.
Can I save decent money by building up a stroker using my existing hardware like the block and heads?
Thank you for any opinions
1970 Super Bee, WM21, 383, auto, FY1, a/c, project! 1971 Chrysler 300 2dr, U-code, console car 1980 Chrysler LeBaron LS Limited coupe 2008 Chrysler Aspen, HEMI 2011 Ram 3500 MegaCab, 6.7
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433109
01/11/18 11:10 PM
01/11/18 11:10 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
They go together pretty easily. You may ask on the DFW LX facebook group if you venture on there at all...
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433143
01/12/18 12:18 AM
01/12/18 12:18 AM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
Grab a 6.4 short block from the dealer and slide it under your heads, cheaper than stroking you current engine and you get a bigger bore for less valve shrouding, very good machine work, already assembled, you can get the BGE or Apache for your choice in compression.
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433330
01/12/18 12:57 PM
01/12/18 12:57 PM
Out West
408strokerdart Offline
Out West
I am in the DFW are and have two different strokers Im putting together right now. I have a very competent machine shop that knows Gen 3 and the "big" builders don't do it any better than I do. Not sure what a short block cost from a dealer, but they never seem "cheap" to me. PM me if you want to talk further about it.
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433380
01/12/18 02:06 PM
01/12/18 02:06 PM
USA
hudsonhornet7x Online content
hudsonhornet7x  Online Content
USA
How much hp would a stock 6.4 hold, with drop in pistons and rods?
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433452
01/12/18 03:52 PM
01/12/18 03:52 PM
Kalispell Mt.
HotRodDave Offline
Kalispell Mt.
Short blocks can be had around $2500 and guys are running big boost to em in 4500# chargers and challengers. Anything under 600hp wouldn't bother me a lick on a stock short block.
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433458
01/12/18 04:02 PM
01/12/18 04:02 PM
Kalispell Mt.
HotRodDave Offline
Kalispell Mt.
The cheapest stroker kit I know of to make a 5.7 into a 392 is $2200 ish SCAT stuff and does not come balanced $175 at my local machine shop, no block, no boreing, honing, not assembled, doubtfull its much if any better than stock apache/BGE stuff.
May just be me but it don't seem worthwhile to stroke a 5.7 unless your building in excess of 600 hp and even then you might just as well start with a hellcat/apache/BGE block and get the bigger bore for $1200 ish for a brand new bare block you can drop your kit into with no aditional machining (well maybe at least get a profeshional to check it over real good, most of the small machine shops don't seem to know how or have the equipment to hold any better tollerances).
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: HotRodDave] #2433473
01/12/18 04:21 PM
01/12/18 04:21 PM
D/FW
gts95 Offline OP
gts95  Offline OP
D/FW
Do you have the dealer part number(s) for the 6.4 shortblock you are referring to?
I'm a newbie at the Gen IIIs, me and my 16yo son (it's his car) are learning though. So BGE is the truck engine, would Apache then be the 6.4 used in the SRT?
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433572
01/12/18 08:16 PM
01/12/18 08:16 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
They aren't a whole lot different than a ls1... so can't see a problem finding someone to build one. Really there's nothing complicated about building one.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433635
01/12/18 10:33 PM
01/12/18 10:33 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
68226133AA Short Block
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433684
01/13/18 12:16 AM
01/13/18 12:16 AM
Australia
L4staero Offline
L4staero  Offline
Australia
5.7 a short motors are only like $1400 last time i checked
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433687
01/13/18 12:19 AM
01/13/18 12:19 AM
Australia
L4staero Offline
L4staero  Offline
Australia
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2433694
01/13/18 12:29 AM
01/13/18 12:29 AM
Kalispell Mt.
HotRodDave Offline
Kalispell Mt.
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: HotRodDave] #2433712
01/13/18 01:31 AM
01/13/18 01:31 AM
Australia
L4staero Offline
L4staero  Offline
Australia
Thats $3579 with the core which he will need to pay as he isnt returning a 6.4 core.
The Eagle will cost him $893 if he returns his 5.7 core
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2434037
01/13/18 07:35 PM
01/13/18 07:35 PM
Kalispell Mt.
HotRodDave Offline
Kalispell Mt.
They must be starting to get greedy or thats just not the best place to buy them, it was about the first place that came up. A few months ago my dealer quoted me about $2500 for either one, no core.
Re: Any machine shops in the DFW area that know Gen III HEMI? [Re: gts95] #2444145
01/31/18 05:34 PM
01/31/18 05:34 PM
MI
P
PREFIX Offline
PREFIX  Offline
P
MI
we do Prefix performance in Michigan we arnt local to you but we know all about genIII hemi's, We bought out the old arrow racing we have an awesome engine team that is all about gen III hemis. We build the hemi motors for the ta2 series and also do a lot of work with Chrysler. I'm sure we can take care of anything that you need or questions you might have. My number here is 248,797,4083
