Re: Dodge 318/5.2 vs 360/9.9 flywheel
[Re: serano]
#2433711
01/13/18 01:28 AM
01/13/18 01:28 AM
Posts: 869 Keizer, Oregon U.S.A.
elmor353
If you plan on using the same trans then yes, the flywheel will be the same size. Rockauto is showing both flywheels to be 143 teeth and sells a replacement flywheel for the 5.9 for under a $100.
[Re: serano]
#2433942
01/13/18 03:56 PM
01/13/18 03:56 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
The 5.9L Magnum needs an offset balance. The factory never made the 5.9L Magnum combination with an NV3500.
The flywheel elmor recommends will only physically fit. It will be neutral balance.
The flywheel you need was never made. I've mated this combo before. I brought a B&M 5.9L Magnum flexplate for an automatic transmission to a machine shop. They copied the offset balance onto a 5.2L neutral balance flywheel.
I do not see a listing for the B&M auto flexplate for 1992 and newer 5.9L listed. They may not make it anymore.
[Re: Magnum]
#2433957
01/13/18 04:21 PM
01/13/18 04:21 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Wrong Go look at the listing for the 5.2 and the 5.9, then look at the pictures, then look at the part numbers, then compare the physical specifications. Except for the imbalance in the 5.9 flywheel (see pic) the specs are the same as the 5.2, however, they are different part numbers, because of the imbalance. Both 1999 Ram 1500 360 Flywheel 318 Flywheel
[Re: serano]
#2433982
01/13/18 05:29 PM
01/13/18 05:29 PM
Posts: 684 Maine
jerseybud
Maine
This flywheel is what you want: https://www.summitracing.com/parts/zzz-50-2754/overview/make/dodgeI'm running this exact part # in my 88 dodge with a 2001 5.9 magnum with all the original MPFI. While it is chinese and there are other manufacturers, this part number will fit a 95 5.9 so that you use a 99 nv3500. There is only 1 flywheel for a 5.9 magnum and only one for a 5.2 magnum from 92-02. That said, I think the 5.2 is scalloped and thats a whole other bucket of worms.
[Re: jerseybud]
#2434556
01/14/18 06:44 PM
01/14/18 06:44 PM
elmor353
The flywheel that you listed from Summit is the exact same flywheel listed at Rockauto, only it's way more expensive from Summit. It's even the same part number. I had thought about using the weight kit, but in my mind, it's just one more thing that could come loose and fly off. Do you friend a favor and get the flywheel from Rockauto.
[Re: Supercuda]
#2435298
01/15/18 11:19 PM
01/15/18 11:19 PM
Magnum
Wrong Go look at the listing for the 5.2 and the 5.9, then look at the pictures, then look at the part numbers, then compare the physical specifications. Except for the imbalance in the 5.9 flywheel (see pic) the specs are the same as the 5.2, however, they are different part numbers, because of the imbalance. Both 1999 Ram 1500 360 Flywheel 318 Flywheel Sorry I did not fully read the reply. Since the factory never offered the 5.9L Magnum balance for a NV3500 I didn't know it existed from the aftermarket. BTW a 10.5 will not work.
