Do you think a 727 would be better? I seem to be having trouble finding reliable info on what transmission to use in a turbo setup, at least for a bigger engine than a 2.5L which I couldn't bring myself to put in my truck.
edit: I don't plan on drag racing much at all, maybe just against friends every once in a while. I want to keep this truck as a daily driver
edit 2: upon finding out the 727 and 518 are basically the same (
http://www.forabodiesonly.com/mopar/threads/a518-vs-727.204137/) I guess I should just use the one that I know will fit. Also, according to
http://www.dakota-truck.net/infosheet.html the a518 was the only v8 rated auto transmission? Is this website just wrong?
