Page 5 of 6 < 1 2 3 4 5 6 >
#2290272 - 04/18/17 08:01 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
This picture is looking to the rear of the car and shows the driver's side subframe connector which channels through the torsion bar crossmember and ties into the forward frame rail:
Same rail just viewed from the side:
Passenger side subframe connector tying into the front subframe rail:
Edited by 70B5Cuda (12/17/17 02:54 PM)
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger rat rod w/ 6.1L/A518/dana 60
1968 Roadrunner w/ 6.1L/6 speed
2010 B5 Challenger SRT 6.1L/6 speed
2008 B5 Charger Super Bee SRT 6.1L/Auto
1996 Dodge Ram 2500 12 valve/5 speed
#2294269 - 04/25/17 11:26 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
The trunk floor pan was really quite solid but there were a couple small holes along the trailing edge that Matt patched:
#2294270 - 04/25/17 11:26 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
Transmission crossmember from the top..
Edited by 70B5Cuda (12/17/17 02:57 PM)
#2294271 - 04/25/17 11:27 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
Master cylinder and pedals were sourced from the Challenger SRT8 I parted out.
Edited by 70B5Cuda (12/17/17 02:58 PM)
#2303687 - 05/13/17 12:18 AM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
The pedals from the 2009 Challenger are mounted with 6 bolts. We tried to mount it with just 4 bolts, but the pedal bracket flexed too much so a plate with two more mounting points was added:
View from the side. it will still be boxed in
Pedals were hung but the and placed the pedals over the steering column hole. The pedals were heated and straightened. Then they were cut and the foot pads were removed/reoriented
Before:
After
Edited by 70B5Cuda (12/17/17 02:59 PM)
#2303688 - 05/13/17 12:19 AM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
A few more pictures of the modified floor pans under the front bucket seats
View from below:
Edited by 70B5Cuda (12/17/17 03:02 PM)
#2303690 - 05/13/17 12:20 AM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
I ordered a shifter with a 1.0" lateral offset (toward the driver) and 4.25" aft offset. Disregard the 4 speed pattern on the handle!
Edited by 70B5Cuda (12/17/17 03:03 PM)
#2308887 - 05/21/17 11:36 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
Here's the first part of the tunnel:
The Holley Dominator ECU mounts to the top of the tunnel near the firewall. You can see it in the next 2 pictures:
Edited by 70B5Cuda (12/17/17 03:28 PM)
#2419945 - 12/17/17 03:29 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
Since the Photobucket extortion attempt, I've been dreading the thread rebuild but I finally bit the bullet and installed all the pictures using imgur.com. If anyone else is still looking for options, you should consider imgur. I've come to like the site in the last week. Anyways...
This is the second section of the tunnel has been roughed in and the new column has been installed. This picture also shown the shifter installed.
#2419946 - 12/17/17 03:31 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
On the rotisserie so the IRS K frame can be welded in:
#2419947 - 12/17/17 03:31 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
Second segment of the tunnel has been welded in. A bezel (seen in bottom right corner) is in process which will have a groove all the way around; carpet will fit into the groove.
#2419948 - 12/17/17 03:32 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
After having the Roadrunner dash powdercoated, I changed directions and bought a 1968 Charger Rallye dash frame off one of the facebook trader pages for $100 plus shipping. Here it is in place:
I also picked up a set of Dakota Digital gauges.
[img]http://i.imgur.com/k2hCd8o.jpg?1[/img]
#2419949 - 12/17/17 03:32 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
IRS getting welded in
#2419950 - 12/17/17 03:33 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
Tunnel from below
#2419951 - 12/17/17 03:33 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
Tunnel and tunnel cover/closeout
#2432186 - 01/10/18 11:06 AM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
Red383 Offline
Loc: OH
Very nice fab work, can't wait to see more.
1970 Plymouth Cuda, 383 4-speed
#2455198 - 02/21/18 03:21 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
Since I eliminated the torsion bars, I have a lot more options for manifolds/headers. Since this car will have about 475-500hp, I decided to go with the factory stainless headers that came on the Jeep Grand Cherokee SRT8. The SRT headers are really durable pieces that also flow very well; they flow as well as any aftermarket shorty header; and SRT headers can easily handle 500hp. Only above that level would longtube headers make a real difference. I couldn't use the factory headers from the Charger/Challenger/etc because they basically point at the firewall in a B body Mopar. The Jeep manifolds point down at a better angle and they hug the block (maybe a little too well) but they will still need some modification on the passenger side in order to clear the bell housing/starter. I also didn't want to spend $750 on a set of mild steel headers that I would have to clearance (ding/dent) anyway.
#2455199 - 02/21/18 03:30 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
The driver's side manifold bumped into the alterktion motor mount so the easiest thing is to modify the motor mount.
The straight piece was removed in favor of a curved pipe. this if the view looking toward the firewall (rearward)
This view is looking forward
I will have tons of room between the frame rails and manifolds. The manifolds will also be easy to remove if need be. I plan to drive this car a lot...
#2455414 - 02/21/18 11:02 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
The passenger side crashed hard against the area on the bell housing where the starter mounts. The manifold wasn't even close to seating/mounting.
Matt sliced the passenger manifold, heated it up, and bent the collector end outward a few degrees. Then he welded it back up. Sorry-the pictures aren't very good but the silver area in the next two pictures is where the slice was made.
#2458963 - 02/28/18 02:06 PM Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda]
70B5Cuda Offline
Loc: Newton, KS
Brake kits are too expensive and since I have parted out SRT8's, I figured I should use what I have. Matt had a bracket machined (and ordered 4 sets for future builds). Now i've got 4 piston Brembo calipers with Dodge rotors (for easy replacement). The other benefit is that my master cylinder and brake pedal are from an SRT Challenger so its a perfect pairing.
25,693 Registered Members
196,707 Topics
1970 Dodge Charger
by tomsjack
01/18/19 03:28 AM
rear disc brake / prop valve question conversion
by superchuck
01/18/19 01:46 AM
Canton Racing Black Accusump canister
by RylisPro
01/18/19 01:22 AM
by RylisPro
01/18/19 01:19 AM
