Re: 99 V10 engine noise...Bad cats??
[Re: dodgedon]
#2230829
01/09/17 03:03 PM
01/09/17 03:03 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
Mine makes the exact same noise. Been doing for years.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: dodgedon]
#2233936
01/14/17 10:37 AM
01/14/17 10:37 AM
Posts: 5,951 Greenville, PA
redraptor
Greenville, PA
I would guess that a dealer would have to plug into the truck to "see" what the timing is doing while running? I was fortunate this independent guy had good equipment, but even then he took it to another shop to confirm it.
[Re: dodgedon]
#2429477
01/05/18 03:57 PM
01/05/18 03:57 PM
Posts: 516 ND
dodgedon
ND
Just wanted to give an update... This summer I had a dealer listen to the truck. He said the timing looked good. He was able to shut off an injector in each cylinder one at a time. He could produce the rattle noise on #2 and #9. He said he thought it was the flex plate rattling. Said it must be cracked...
Any thoughts on this?
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: buildanother]
#2429919
01/06/18 02:09 PM
01/06/18 02:09 PM
Posts: 516 ND
dodgedon
ND
The tech never said anything about the timing chains on these engines. He didn't believe anything was wrong inside the engine. We both listened to the rattle and It does sound like its coming from the rear... I guess my question is how can i know for sure it is the flex plate? I took the cover off and cant see any cracks. He said it would crack around the crank bolts, And you cant see them from the bottom.
If I took the torque converter bolts out and pushed it back, could I run the engine to see if the noise is gone? Is there enough clearance for that?
[Re: dodgedon]
#2430396
01/07/18 09:19 AM
01/07/18 09:19 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
Pull the trans. If you were to run the engine disconnected from the torque converter you will gall the pilot hole in the crank and the converter hub and without any load on the flex plate it may not make any noise.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2430436
01/07/18 12:44 PM
01/07/18 12:44 PM
Posts: 516 ND
dodgedon
ND
Thank you, I figured there wouldn't be enough clearance. That's a lot of work to pull it back just to look but I don't have any other options do I? Being able to run it without load on the plate was the reason I wanted to try that.
If it is the flex plate the next problem is they are discontinued.... Is there any aftermarket options, or am i looking for a used one?
[Re: dodgedon]
#2430481
01/07/18 01:55 PM
01/07/18 01:55 PM
Guitar Jones
Try a google search you can probably find one on ebay.
[Re: Guitar Jones]
#2431084
01/08/18 03:22 PM
01/08/18 03:22 PM
Posts: 4,562 Motor City
6PKRTSE
Motor City
My 96 V10 Ram has 168,000 on it now, the cats have been rattling for years. I just turn the radio up louder. LOL. One of these days I will just delete them. They do not seem to effect power or performance thus far.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: d-150]
#2431131
01/08/18 04:33 PM
01/08/18 04:33 PM
Posts: 516 ND
dodgedon
ND
IF you read this post from the beginning you will see that I did fix the exhaust. That was not the problem. A tech said he thinks its the flex plate. I'm looking for thoughts on this... As in are these flex plates know to crack? How Can I know for sure with out pulling back the trans? This truck only has 80,000 miles.
[Re: dodgedon]
#2431184
01/08/18 06:48 PM
01/08/18 06:48 PM
Posts: 10,125 A Red State
SNK-EYZ
A Red State
IIRC you should be able to see a fair amount of the flexplate with the dust shield off the lower bellhousing. Do a visual inspection and then do another check with it running to see if you can isolate the noise to the bellhousing area.
[Re: SNK-EYZ]
#2431328
01/08/18 10:55 PM
01/08/18 10:55 PM
Posts: 516 ND
dodgedon
ND
I did do that earlier today. I had the cover off and ran it. It looks good but you can't see the center where the crank bolts are. I will admit its very loud with the cover off on start up, then the noise goes away.... I'm in the process of pulling the trans back. I will report what I find.
[Re: dodgedon]
#2433770
01/13/18 04:48 AM
01/13/18 04:48 AM
Posts: 516 ND
dodgedon
ND
Its not the flex plate. I think I found the problem though. I pulled the pan off and the rod bearings seem too loose... I will investigate more when I have time. Didn't expect that as it has really good oil pressure.
[Re: 440_Offroader]
#2434231
01/14/18 02:07 AM
01/14/18 02:07 AM
Posts: 516 ND
dodgedon
ND
It was actually just the opposite. No engine noise when at idle. He would shut off the cylinder and it would rattle. Turn it back on and the noise would stop. I did ask about wrist pins that day and he did agree that yes when an engine would come in knocking as they turned off the cylinder it would go away. He thought the engine just ran to smooth to be internal. He felt that as they turned off the cylinder the missing was shaking the crank and the possibly cracked flex plate.
I have been trying to figure out this rattle for like 4 years. I have asked here, other dealers and shops, everyone said it was exhaust rattling, nothing or normal sounds.. I drive trucks every day and just never believed this was normal "sounds". Never wanted to just start taking everything apart without knowing for sure what was wrong.
[Re: chargers777]
#2434853
01/15/18 05:02 AM
01/15/18 05:02 AM
Posts: 516 ND
dodgedon
ND
I will look at it more this week. I didn't look to closely at the chain but I did see it when looking up from the bottom. Didn't notice anything unusual about it. But now is the time to be sure when its all apart.
