IMO for what you have you should be able to make it work with those shocks for sure. Strange does offer rebuild and revalving service as well. Id start with a call to them if you think there is a shock issue. Video goes a long way to diagnosing these types of issues.
Thanks Al. I will call strange. Shocks were re valved stiffer about 6 years ago. Could they be worn out?
July 2016 on a well prepped track I went tighter with ext until it wouldn't hook.
Ended up on #6 ext. with a 1.248 60'.
Runs before that I loosened front ext to 2 from full soft. It definitely hooks better with soft ext on front.
Track temp was low but it was when I could test.
Also FWIW My IC is 50" out and 7.25" high
Wheelie bars are 10" and 10.5"
What do you all think of the set up?
Thanks again for your help!
Don
