Innovate lm-2 question #2430571
01/07/18 04:29 PM
01/07/18 04:29 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
This last summer while working on dialing the new combo in I ran across an issue with my Lm-2 and the use of a SDHC memory card as opposed to the older SD card and having the LM-2 recognize and accept the newer card, I can install the older card and it works but the new card it will come upon the screen as (card?),are these not compatable to the new SDHC card and would need to be sent back to Innovate and updated to make it compatable or am I doing somthing wrong?? the older SD cards are getting harder to find and and I have not found them locally.
Re: Innovate lm-2 question [Re: dartman366] #2430630
01/07/18 06:21 PM
01/07/18 06:21 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Innovate might have their own card format that needs to be performed. There might be a link on their website or they might be able to upload you the format program to you. Either way, it would be worth a phone call.
[image][/image]
Re: Innovate lm-2 question [Re: sgcuda] #2430642
01/07/18 06:44 PM
01/07/18 06:44 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
It's in the directions and on site. Y ou CANNOT use the HC cards.
Don
Re: Innovate lm-2 question [Re: cudadon] #2430732
01/07/18 09:35 PM
01/07/18 09:35 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Don
Thanks Don, my directions are pre- SDHC, as is my meter, that is why I did not know untill I went to the web site (after seeing your post) and researched it and found the info in the specification's sheet, my earlier version did not have that requirement, now I need to find a source of these card's, damned technology.
Re: Innovate lm-2 question [Re: dartman366] #2431050
01/08/18 02:21 PM
01/08/18 02:21 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I looked on ebag those small sizes are hard to find anymore.
OR you can save the runs/logs on that sd to your comp. or a thumb drive etc. Then delete them from the sd and continue using it.
Don
Re: Innovate lm-2 question [Re: cudadon] #2431205
01/08/18 07:37 PM
01/08/18 07:37 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Don
may try that if I cannot find some. thank you.
