Factory paint the back of the engine? #2430311
01/07/18 01:37 AM
01/07/18 01:37 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Trying to determine if this engine has been rebuilt & I've never noticed the back of a engine painted, is this typical? This is a '72 360 & I am going to put core plugs in & clean it up just trying to determine if it's been into.
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: Factory paint the back of the engine? [Re: grancuda] #2430314
01/07/18 01:42 AM
01/07/18 01:42 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Automatic transmission block applications will have some over spray.
Manual transmission block applications had the bell housing mounted before paint.
Re: Factory paint the back of the engine? [Re: grancuda] #2430316
01/07/18 01:47 AM
01/07/18 01:47 AM
n.c.
geo. Offline
geo.  Offline
n.c.
That's been my experience too, no paint on the transmission side.
See if it still has stock head gaskets, usually you can see the edge of the gskt.
Re: Factory paint the back of the engine? [Re: grancuda] #2430320
01/07/18 02:01 AM
01/07/18 02:01 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Looks like the motor was painted with the flex plate & torq converter hooked up.
Would the head gaskets be steel shim gaskets?
The motor is from a 70k mile truck strong running 360, pretty uniform compression & clean plugs.
All I am planning on doing is pulling the oil pan, the timing cover assy. off & checking timing chain slack & putting new water pump/gaskets/core plugs.
Also adding an aluminium intake, someone put a early '80's quadrajet intake/carb & I have a new Holley SA 670 off my '67 Barracuda I only ran a month or so.
2021 Toyota Supra
Re: Factory paint the back of the engine? [Re: grancuda] #2430388
01/07/18 07:24 AM
01/07/18 07:24 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Bolt heads is what I look at Grancuda to see if something has been opened up. twocents
Mo' Farts
Moderated by "tbagger".
Re: Factory paint the back of the engine? [Re: grancuda] #2430444
01/07/18 01:00 PM
01/07/18 01:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I would agree that it looks like factory paint. Any signs of paint on the distributor or clamp?
Re: Factory paint the back of the engine? [Re: ScottSmith_Harms] #2430464
01/07/18 01:31 PM
01/07/18 01:31 PM
New York
rarefish Offline
rarefish  Offline
New York
Back of my 1969 340 block with factory paint still on. It is a 4 speed car.
Re: Factory paint the back of the engine? [Re: grancuda] #2432650
01/11/18 02:59 AM
01/11/18 02:59 AM
n.c.
geo. Offline
geo.  Offline
n.c.
You can turn the crank counter clockwise with a breaker bar, after taking out the slack in the normal direction. Observe how far the mark on the balancer moves before the rotor starts to turn. Might save you the trouble taking the cover off.
Not sure when the 360s had steel shim gaskets, sorry. My '85 Ram came with a quadrajet, ran well, but carb wasn't made very well and I was constantly messing with it. Good you've got an option.
