#2430239 - 01/06/18 08:30 PM Noise from intake/pcv area 2014 5.7
larrymopar360 Offline
Loc: Central Florida
I have what I can best describe as a churning noise coming from my 2014 Charger Police with 5.7, with only 3800 miles. Car runs great, no engine lights, and I cannot hear the sound from inside car when driving, only when idling. Mechanic used his stethoscope and could hear it in the intake area. We then felt the PCV hoses (I have a BT catch can) and you can feel it in one of the hoses. It's not a steady thing, like I wrote, it's kind of a cyclical churning, almost a grinding but not that rough. I wish I were better at posting video.
Car is well maintained, everything looks normal under hood, no kinked PVC hoses, and definitely does not sound anything like one of the common issues with the 5.7's, e.g., lifter tick.
Any info?
Thank you
Facts are stubborn things.
#2448005 - 02/07/18 11:15 AM Re: Noise from intake/pcv area 2014 5.7 [Re: larrymopar360]
70blackfish Offline
Loc: SO. CAL.
did you mod the air filter ? the oil fill has a 3/4 nipple off of it...did you plug it ?
10.30 @132mph
496 big block, Solid Roller, Ported Victor Heads.
8 inch converter, pro trans. Cal-tracs.
dana 60 4.10 w/locker.
Street Car. SOLD...........
#2452218 - 02/15/18 02:15 PM Re: Noise from intake/pcv area 2014 5.7 [Re: larrymopar360]
Ok, it was Water Pump, to my surprise. That's an early failure! We've had no early failures on any of our Police Chargers at work that I know of, and I'm pretty in tune with the maintenance of them. Guess I just had a bad one. It was strange that I could feel it in one of the PCV hoses running off the catch can. Dealership installed new pump and coolant, free of charge seeing how it's only got 4300 miles, and it's smooth and quiet again.
Thanks all.
Larry
#2452383 - 02/15/18 09:25 PM Re: Noise from intake/pcv area 2014 5.7 [Re: larrymopar360]
biff426 Offline
Loc: Delaware
I have a 2011 police package and the pump has been replaced 3 times in 76000 miles in my opinion the belt tensioner is killing them way too much tension. The last one I replaced 2 months ago had ground into the timing cover where the impeller spins.
25,693 Registered Members
196,707 Topics
1970 Dodge Charger
by tomsjack
01/18/19 03:28 AM
rear disc brake / prop valve question conversion
by superchuck
01/18/19 01:46 AM
Canton Racing Black Accusump canister
by RylisPro
01/18/19 01:22 AM
by RylisPro
01/18/19 01:19 AM
