Page 3 of 5 1 2 3 4 5
Re: Carb suggestions, looking at going Holley [Re: Thumperdart] #2421203
12/19/17 11:27 PM
12/19/17 11:27 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
1.45 venturi and 1.75 throttle blades. Its supposedly flows 950 cfm but I'm not convinced.
Re: Carb suggestions, looking at going Holley [Re: Belvedere1] #2421205
12/19/17 11:30 PM
12/19/17 11:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not quite but should work..........
Re: Carb suggestions, looking at going Holley-Update [Re: Thumperdart] #2421234
12/20/17 12:03 AM
12/20/17 12:03 AM
Phoenix, AZ
Phoenix, AZ
I agree, as long as its not less than 800 I don't really care.
Update:
I got the carb on and the car running again. It runs great right out of the box, the one and only adjustment was the idle speed. The float levels were spot on too. It was tweaked slightly from the box stock settings by the guy I bought it from. It seems that he nailed the settings. Jet 78/86, 4.5 power valve, rear blocked, idle restrictor .037, idle bleeds .030, high speed .073, 35 squirters front and rear, 30cc cam in front and 50 in rear. The only issue that is still there that I had with the Edelbrock 800 is at a warm idle when the engine starts to shudder like it drops a cylinder then picks back up again. The idle is better with this carb but the shuddering is still there. I'm at a loss from where to go from here on that.
Re: Carb suggestions, looking at going Holley-Update [Re: Belvedere1] #2428488
01/03/18 09:19 PM
01/03/18 09:19 PM
Phoenix, AZ
Phoenix, AZ
BTT
Re: Carb suggestions, looking at going Holley [Re: Belvedere1] #2428560
01/03/18 11:04 PM
01/03/18 11:04 PM
central Pa.
71Pan Online content
71Pan  Online Content
central Pa.
Holley 3310 heavier vehicle street driven that's what I would buy get secondary spring set and forget it and run it
Re: Carb suggestions, looking at going Holley-Update [Re: 71Pan] #2428773
01/04/18 11:13 AM
01/04/18 11:13 AM
Phoenix, AZ
Phoenix, AZ
That would be a major step down from what I just bought, IMO.
Re: Carb suggestions, looking at going Holley-Update [Re: Belvedere1] #2428916
01/04/18 03:24 PM
01/04/18 03:24 PM
Look for a vacuum leak or a bad spark plug wire or spark plug scope
Re: Carb suggestions, looking at going Holley-Update [Re: Cab_Burge] #2429246
01/04/18 11:37 PM
01/04/18 11:37 PM
Phoenix, AZ
Phoenix, AZ
Fresh plugs, have inspected every inch of each wire and boot and no sign of anything that looks suspect on those. Ive done all the vacuum leak checks known to man and cannot find one. I may try and crank the timing to 24 intial and see if that changes anything???
Re: Carb suggestions, looking at going Holley-Update [Re: Belvedere1] #2429312
01/05/18 02:49 AM
01/05/18 02:49 AM
AndyF Offline
AndyF  Offline
You might need to get the car on a scope to trace down a problem like that. My guess is that it is electrical and probably something thermal related. Most likely a bad coil or a bad part in the ignition box. When it gets hot you have a solder joint opening up or something like that. Very hard to find without a scope or other test equipment. If you have a buddy who has the same ignition system as you maybe you can swap coils and boxes and stuff like that until you run it down. I doubt it is carb related.
Re: Carb suggestions, looking at going Holley-Update [Re: Belvedere1] #2429344
01/05/18 06:22 AM
01/05/18 06:22 AM
central Pa.
central Pa.
That's hard to say unless you make back to back passes bench racing YES
Re: Carb suggestions, looking at going Holley-Update [Re: AndyF] #2429376
01/05/18 11:06 AM
01/05/18 11:06 AM
Phoenix, AZ
Phoenix, AZ
The baffling part is that its just the idle only but anything is possible with electrical issues in my experience. I started down that road a few months back with swapping to an old known good orange box and a stock coil with no change. I'm using a chrome box and an MSD Blaster coil. I'll see if a buddy of mine still has his scope at his shop.
Re: Carb suggestions, looking at going Holley-Update [Re: Belvedere1] #2429657
01/05/18 10:27 PM
01/05/18 10:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By Belvedere1
......The only issue that is still there that I had with the Edelbrock 800 is at a warm idle when the engine starts to shudder like it drops a cylinder then picks back up again. The idle is better with this carb but the shuddering is still there. I'm at a loss from where to go from here on that.
Can you add some more description around this? Not real clear what happens and when.
Re: Carb suggestions, looking at going Holley-Update [Re: BSB67] #2429712
01/06/18 12:24 AM
01/06/18 12:24 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
These Thumper carbs are very nice up
Re: Carb suggestions, looking at going Holley-Update [Re: BSB67] #2429741
01/06/18 01:47 AM
01/06/18 01:47 AM
Phoenix, AZ
Phoenix, AZ
At anything from just a couple minutes after start up to just about 180 on the water temp gauge the idle is smooth or as smooth as it can be given the cam with a very consistent idle. When the temp gets to normal operating the idle rpm in gear will get a little erratic almost to the point of it feeling like it drops a cylinder and picks back up and then feels like a miss again, and on and on. In gear idle is around 800 and in park it will smooth out slightly at around 1000 to 1100. The best vacuum reading I get is 10 with an initial timing setting of 20. I thought the problem with the old Edelbrock carb was it not getting a decent vacuum signal causing the metering rods to bounce up and down and the carb to hunt between the idle and main circuit. This new carb made things overall slightly better.
Re: Carb suggestions, looking at going Holley-Update [Re: ccdave] #2429742
01/06/18 01:49 AM
01/06/18 01:49 AM
Phoenix, AZ
Phoenix, AZ
That looks too nice to get dirty! He is great and helped me a ton in choosing the carb I bought.
Re: Carb suggestions, looking at going Holley-Update [Re: Belvedere1] #2429771
01/06/18 03:05 AM
01/06/18 03:05 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Fat it up a taste and see what happens. The low vac. signal probably isn't allowing the manifold to get "wet". I have a 400 with a big cam and I had to make it idle a little fat but it's happy.
Re: Carb suggestions, looking at going Holley-Update [Re: Belvedere1] #2429912
01/06/18 02:05 PM
01/06/18 02:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do your self(and us)a favor and install a wide band and venture into the REAL tuning zone but be prepared to learn more about carbs than you imagined and have a damn near EFI running machine.......... beer
Re: Carb suggestions, looking at going Holley-Update [Re: Thumperdart] #2430029
01/06/18 04:26 PM
01/06/18 04:26 PM
Phoenix, AZ
Phoenix, AZ
I tried another stock parts store replacement ECU I find that I didnt realize I had with no change on the idle. I'll throw another coil on there the next time I get the car out. I tried an extremely rich jet and rod combo on the old carb and that didnt help the situation either. I totally agree on fine tuning with a wideband but how useful would it be just to establish a base idle and is there a such a thing as a no weld O2 bung kit?
Re: Carb suggestions, looking at going Holley-Update [Re: Belvedere1] #2430036
01/06/18 04:41 PM
01/06/18 04:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You can buy the clamp to the exhaust deal or just chassis dyno it then tune to suit your needs but even dynos run WB's it's the BEST and you're guessing otherwise............
Re: Carb suggestions, looking at going Holley-Update [Re: Belvedere1] #2430038
01/06/18 04:42 PM
01/06/18 04:42 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Okay. Thanks
I still would not rule out a vacuum leak, but I'm thinking you simply need to get into the weed on your idle tune-up. That size cam at 800 rpm in gear needs to be right, IMO. Without an A/F meter, I would maybe start with a bit more initial timing (make sure that it is not moving between 800 and 1100 rpm too) and try a bit fatter.
The only vacuum leak method that always works for me is the simple hand over the carb test.
