68Charger gauge cluster and switch install screw/U nut set? #2428957
01/04/18 04:38 PM
01/04/18 04:38 PM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
Is there a screw kit available that has all the screws/nuts for installing the gauges and switches in a 68? Also is there a thread or pictures of how they all go? It’s been about a decade since I took mine apart. I need all the hardware that would be attached to the dash and the screws for installing the gauge cluster into the dash and switches into the cluster.
Re: 68Charger gauge cluster and switch install screw/U nut set? [Re: challenger70] #2428979
01/04/18 05:15 PM
01/04/18 05:15 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
